1. Ceedawg
    Ceedawg Well-Known Member
    432
    301
    Aug 2, 2016
    Va
    Local Time:
    1:44 PM
    What was used for the heat stove on this intake? Stock choke piece doesn’t fit
  2. cudamark
    cudamark FABO Gold Member FABO Gold Member
    8,578
    1231
    Mar 14, 2009
    San Diego
    Local Time:
    10:44 AM
    What year choke are you trying to use? Maybe some photos?
    • Agree Agree x 1
    • gzig5
      gzig5 FABO Gold Member FABO Gold Member
      1,720
      1886
      May 3, 2018
      Mequon, WI
      Local Time:
      12:44 PM
      I don't think the LD340 ( or any aftermarket intake ) was designed to use a stock style thermal choke. Would probably have a Holley mounted or convert to electric or manual choke.
    • toolmanmike
      toolmanmike FABO MODERATOR Staff Member FABO Gold Member
      59,734
      47310
      Jan 18, 2006
      Iowa
      Local Time:
      12:44 PM
      I have seen little choke coils that would fasten to the 2 screws here. upload_2021-1-15_15-53-52.png
      • Agree Agree x 3
      • toolmanmike
        59,734
        47310
        Jan 18, 2006
        Iowa
        Local Time:
        12:44 PM
        • Like Like x 2
        • autoxcuda
          autoxcuda Well-Known Member
          7,278
          1520
          Apr 6, 2007
          Local Time:
          10:44 AM
          There are some generic choke coils that bolt to that. I have one on my large port dual plane Weiand intake.
          iirc they come with the coil ends on either side. There is a pin that locates them but flipping them changes the offset of the coils.
          can’t remember if they come in different opening rates.
          the Tomco 9007 is for sure one. You can see the outline matched toolmanmike’s pic. Not sure is the Standard CV-76 is one. I think one has the lever attachment on the wrong side.
          you’ll have to look it up those part numbers and figure which is right.
          PS. Toolmanmike, is Champion Auto still in business ?
          • Like Like x 1
          • autoxcuda
            7,278
            1520
            Apr 6, 2007
            Local Time:
            10:44 AM
            • Like Like x 1
            • krazykuda
              krazykuda Well-Known Member FABO Gold Member How-To Section Editor
              59,310
              25139
              Aug 20, 2007
              Orland Park, IL
              Local Time:
              12:44 PM
              I like to use electric choke carbs on my LD340's....
              • Agree Agree x 3
              • Like Like x 1
              • toolmanmike
                59,734
                47310
                Jan 18, 2006
                Iowa
                Local Time:
                12:44 PM
                I have a electric and a oem choke on my 2 cars. I must have them adjusted proper because both work pretty flawless.
                • Like Like x 1
                • autoxcuda
                  7,278
                  1520
                  Apr 6, 2007
                  Local Time:
                  10:44 AM
                  Here they are.
                  they are stamped 32 and 39 on the bottom. Don’t know what that means.
                  the hooks aren’t pulled all the way down cause it’s 85 degrees in my garage :D
                  • Like Like x 1
                  • toolmanmike
                    59,734
                    47310
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    12:44 PM
                    • Agree Agree x 2
                    • Ceedawg
                      432
                      301
                      Aug 2, 2016
                      Va
                      Local Time:
                      1:44 PM
                      Yea that looks good, do they have a cover? Going one of two ways here, AVS or TQ, since I have about ten of each plus a few new carters and Edelbrocks, reason for the hot choke.
                      Where are those sold at?
                    • autoxcuda
                      7,278
                      1520
                      Apr 6, 2007
                      Local Time:
                      10:44 AM
                      mike showed you a link to Summit Racing.
                      I would google those part numbers and put them in rockauto.com to check
                      I saw these two on summit on bottom of that page Mike linked to. One is $11.99. I can’t see a difference other than hook location
                      you’ll need to make a Z-bar out of rod for the choke attachment. Then you bend the Z part to shorten or lengthen the rod for fine adjustments
                      • Like Like x 2
                      • Ceedawg
                        432
                        301
                        Aug 2, 2016
                        Va
                        Local Time:
                        1:44 PM
                        I’m guessing one push’s up and the other pulls down, sorry didn’t see the link.
                        Didn’t the early Chevys have something like that?
                      • autoxcuda
                        7,278
                        1520
                        Apr 6, 2007
                        Local Time:
                        10:44 AM
                        iirc, I’ve heard Chevy used them. I think they might have had a cover OE.
                        All 3 on summit and the two I have push up.
                        if they pulled down, then when cold the hook hole would be on top.
                      • TX9 340 Plymouth
                        TX9 340 Plymouth Active Member
                        31
                        34
                        Feb 7, 2012
                        On your 6 o'clock
                        Local Time:
                        1:44 PM
                        I used the same set up on my LD340.
                        • Like Like x 3
                        • Thanks! Thanks! x 3
                        • TX9 340 Plymouth
                          31
                          34
                          Feb 7, 2012
                          On your 6 o'clock
                          Local Time:
                          1:44 PM
                          • Thanks! Thanks! x 2
                          • toolmanmike
                            59,734
                            47310
                            Jan 18, 2006
                            Iowa
                            Local Time:
                            12:44 PM
                            • Agree Agree x 1
                            • Ceedawg
                              432
                              301
                              Aug 2, 2016
                              Va
                              Local Time:
                              1:44 PM
                              Thanks, I knew you guys would come thru for the help!
                              • Like Like x 1
                              • autoxcuda
                                7,278
                                1520
                                Apr 6, 2007
                                Local Time:
                                10:44 AM
                                Excellent detailed info.
                                Really nice! :thankyou::thumbsup:
                                Note: those Chevy ones shown are all “pull down” . You can see the hook hole on top when cold.
                                Also: you can use the Chevy cover shown with other “push up” mechanisms. If you need to. I used a “push up” with my AVS. But there was plenty of room to use either. Just depended on how you bend the rod.
