leaf spring bushings/Grease
Suspension, Steering and Chassis
  1. 65Vart
    65Vart Well-Known Member
    3,146
    30
    Feb 13, 2009
    Waterdown, Ontario
    Local Time:
    7:21 AM
    I'm just about to replace the leaf springs on my 71 dart,
    I have new springs with the front bushings installed and a new rear shackle kit with rubber bushings. Should I use grease on the rear rubber bushings? and, if so , what is recommended?
    Thanks
  2. Valiant63
    Valiant63 Early A-body Valiants
    1,382
    327
    Dec 29, 2007
    eastern, PA and central Florida
    Local Time:
    6:21 AM
    Don't use grease. It will break down the rubber in the bushing. Use a silicone based lubricant if you need to install. Otherwise, it isn't needed.
    • Agree Agree x 4
    • 65Vart
      3,146
      30
      Feb 13, 2009
      Waterdown, Ontario
      Local Time:
      7:21 AM
      Thanks
    • Syleng1
      Syleng1 Karma is real and Life is short... FABO Gold Member
      1,350
      928
      Jul 5, 2005
      North Franklin, CT
      Local Time:
      7:21 AM
      Do it dry baby!
    • Unconventional
      Unconventional Well-Known Member
      8,485
      7764
      Apr 17, 2017
      Santa Maria, Ca.
      Local Time:
      4:21 AM
      Liquid soap or flax soap as in tire mounting should make them slip in a little easier. Water soluble too.
    • ir3333
      ir3333 Well-Known Member
      4,472
      1058
      Jun 1, 2008
      ontario,canada
      Local Time:
      6:21 AM
      if the rear shackles are stock i think they will tighten to the stops with the correct
      amount of pressure on the rubber bushing...i'd leave them dry.
    • cannucky
      cannucky The Guy With No Birthday
      5,758
      673
      Sep 25, 2008
      Portage Du Fort QC
      Local Time:
      4:21 AM
      I use headlight fluid during assembly .
    • Unconventional
      8,485
      7764
      Apr 17, 2017
      Santa Maria, Ca.
      Local Time:
      4:21 AM
      Blinker fluid works well too. In an intermittant sort of way.
    • 69_340_GTS
      69_340_GTS Well-Known Member
      3,775
      1669
      Jul 11, 2014
      Torrington, CT
      Local Time:
      7:21 AM
      I wouldn't grease those bushings either. However, maybe synthetic lube is okay to use? I just saw Mark Worman insist that they all be lubed. He says they'll squeak if you don't. He used that red lube on them (which is probably synthetic AFAIK).
    • Syleng1
      1,350
      928
      Jul 5, 2005
      North Franklin, CT
      Local Time:
      7:21 AM
      How about a bucket of steam?
      I have always used plain jane wheel bearing grease on the rears.
      Factory manuals states," Coat both ends of torsion bar with Multi-milage Lubricant, Part Number: 2525035 or equivalent."
      If you call your local Chrysler parts dealer parts dept and give them that number they can cross it up to a recent number.
      joe
    • cannucky
      5,758
      673
      Sep 25, 2008
      Portage Du Fort QC
      Local Time:
      4:21 AM
      Cool except we're talking about leaf spring bushings not torsion bars .
    • Syleng1
      1,350
      928
      Jul 5, 2005
      North Franklin, CT
      Local Time:
      7:21 AM
      WOW! I think I responded to the wrong post. I am so sorry- I just got very excited to help- Joe
    • cosgig
      cosgig MoBro Inc. FABO Gold Member
      11,170
      4101
      Jul 20, 2008
      Pinckney, Michigan
      Local Time:
      6:21 AM
      I use a silicone based lube, much like the caliper grease that you get in the small tubes! It keeps them from seizing in the spring or in the pin! They do suggest using it for poly bushings as well!
      • Agree Agree x 1
      • rednesss
        rednesss FABO Gold Member FABO Gold Member
        1,456
        147
        Mar 4, 2006
        Eugene, OR
        Local Time:
        4:21 AM
      • cosgig
        11,170
        4101
        Jul 20, 2008
        Pinckney, Michigan
        Local Time:
        6:21 AM
      • rednesss
        1,456
        147
        Mar 4, 2006
        Eugene, OR
        Local Time:
        4:21 AM
        Yep, nice and sticky. Magic green goo.
