leaking coolant.
rabius75
Dallas, GA
i found out where its going.
BACK INTO MY CAR AGAIN!!!
its leaking from the firewall, it didnt this over the summer. so i unhooked the heater core, and it was fine. then i hooked it back up, and it was fine. now its leaking in the same place, somewhere around the firewall where the heater core hooks up to the lines.
GRRR
Are you sure it isn't the heater core itself?
99% of the time that's what leaks.
it may be. im too lazy to pull it all out and look. ill probably wait until it gets a little warmer so i can unhook it
My engne started leaking coolant also.
Thermostat housing gasket Again :sad2: . I already fixed this over the summer. I hope the coolant didn't freeze. When I took it apar before I cleaned the crap out of everything. new gaskets and sealer and all was fine till a few days ago when I see the coolant leaking out.
The lower radiator hose is also leaking at the water pump inlet..
