LED 7" Round Headlights Upgrade!!
How to install BRIGHT 7" LED Round Headlights in your Later A Body for a great price and easy plug-in play installation!!
Rating:
5/5,
  1. gwmax65
    gwmax65 Magnum V8 Mopar
    120
    75
    May 17, 2013
    Utah
    Local Time:
    3:28 PM
    gwmax65 submitted a new Article:
    LED 7" Round Projector Headlights Upgrade!!
    Read more about this article here...
    • Like Like x 2
    • jos51700
      jos51700 Well-Known Member
      5,176
      1858
      May 24, 2009
      Bel-Ray
      Local Time:
      4:28 PM
      Linkie no workie.
    • 6pk2goDemon
      6pk2goDemon Mopar Mod Staff Member FABO Gold Member
      11,454
      2599
      Mar 1, 2008
      Arizona
      Local Time:
      2:28 PM
      The link works now...
    • Joeychgo
      Joeychgo FABO Administrator Staff Member
      3,920
      2338
      Apr 24, 2005
      Chicago, Illinois
      Local Time:
      4:28 PM
      Interesting....
    • Dizzydean
      Dizzydean Well-Known Member
      902
      19
      Mar 26, 2007
      Richland (Tri Citys) Wash
      Local Time:
      3:28 PM
      Could you just plug the yellow and red into the running light plugs and use that instead or are all running lights being used?
      • Disagree Disagree x 1
      • enigma57
        enigma57 Well-Known Member
        312
        279
        Apr 8, 2012
        Texas
        Local Time:
        4:28 PM
        Thanks for posting! Great article. I have a question. I want to upgrade my headlights but do not want the 'halo' feature. Will these lights wire up similarly? And because they are 150W total, will I need an additional relay or heavier gauge wiring? Sorry if this is a dumb question, but I am more comfortable turning wrenches than wiring things......
        2X 7Inch Round 150W Total CREE LED Headlights Hi/Lo 97-17 JEEP JK TJ LJ Wrangler 873031872430 | eBay
        Thanks,
        Harry
      • gwmax65
        120
        75
        May 17, 2013
        Utah
        Local Time:
        3:28 PM
        You'll have to splice into the running light harness to have the halo's work, so either way, if you just want the halos only vs the running lights in the grille or bumper, just remove the bulbs from there.
      • gwmax65
        120
        75
        May 17, 2013
        Utah
        Local Time:
        3:28 PM
        They have the H4 connector so I don't see why they wouldn't work. I am not sure, being an LED system they should draw less current than halogens, I'd suggest first trying them out without running a relay wiring harness, plug into stock harness. If you see flickering going on constantly, then it probably wouldn't hurt to get a relay wiring harness, those run around $20-$30 on eBay, easy to wire up, the relay harness plugs into your stock H4 harness and then you simply run the + wires to the + side of the battery or charge post of the alternator, or starter relay + post, the headlight switch will act as the remote signal to turn the relays on, bridging a clean +12V from the battery straight to the headlights.
        • Thanks! Thanks! x 1
        • enigma57
          312
          279
          Apr 8, 2012
          Texas
          Local Time:
          4:28 PM
          Much appreciated! That's good to know. Should make the changeover easier.
          I forgot about the current draw being less with LEDs. That will help. FWIW...... I replaced the tail light bulbs in my wife's car with LED bulbs and because they draw less current, the flasher inside the car 'ticks' faster when we use turn signals now, same as if a bulb were burned out (also lowering current draw). Lights still flash at normal speed outside when turn signal is used, though. Her car is a 2013 VW Passat and since I replaced the tail light bulbs, a message flashes on her dash from time to time to 'check tail light'. No issues having car inspected, so we just disregard the warning message.
          Thanks,
          Harry
        • gwmax65
          120
          75
          May 17, 2013
          Utah
          Local Time:
          3:28 PM
          Anytime :). They do sell what they call LED flasher relays to replace the stock one. For some reason the stock relay doesn't know what to do with the excess voltage when those LED bulbs are installed, drawing less voltage (like you said), so it freaks out. The LED flashers are designed to handle the voltage properly and make it function like it's supposed to, check it out on eBay, make model year + LED flasher, probably less than $10. Had to do the same in my '01 Ram sport truck when I swapped over to LEDs. Will be doing the same to this Scamp soon.
          • enigma57
            312
            279
            Apr 8, 2012
            Texas
            Local Time:
            4:28 PM
            :thumbsup: Outstanding! I'll check that out. Sounds like just what we need for both our cars here. Thanks for the info!
            Best regards,
            Harry
          • 383 fish
            383 fish Member
            11
            4
            Jan 18, 2016
            Wisconsin
            Local Time:
            4:28 PM
            Thanks for the article, very informative!
            PTS
            • coyoteduster
              coyoteduster Moldy Oldy
              72
              6
              Feb 26, 2013
              Oklahoma
              Local Time:
              4:28 PM
            • slantsixdan
              slantsixdan =..=
              6,447
              1552
              Jan 7, 2007
              Vancouver BC
              Local Time:
              2:28 PM
              Headlamps are like brakes and seatbelts: most of the time you don't need much of 'em until you very suddenly, very urgently do. To keep you out of a crash (or worse), safety equipment like headlamps, turn signals, and so on actually have to work safely—it's not enough that the seller of a Chinese trinket says "It's a headlamp" or "It's a turn signal", and unfortunately we live in a world where we don't get what we don't pay for. See here.
              • Agree Agree x 1
              • coyoteduster
                72
                6
                Feb 26, 2013
                Oklahoma
                Local Time:
                4:28 PM
                WOW, the things we learn on this board.. thanks Dan.. a LOT I didn't know or even realize.. I suppose sometimes we let fancy get in the way of safety unless someone reminds us..
                Ok now for the pun.. I feel I have been.. enLIGHTened. I know, BAD joke...
                • Like Like x 2
                • RustyRatRod
                  RustyRatRod Weenie idiot loser. FABO Gold Member
                  58,506
                  28930
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  5:28 PM
                  How are these for light focus? I've both heard and read that the LEDs are not focused well and have a lot of light scatter. Did you find some good ones?
                • Mattax
                  Mattax Just the facts, ma'am FABO Gold Member
                  9,499
                  5828
                  Feb 7, 2013
                  Phila. Pa
                  Local Time:
                  5:28 PM
                  JWSpeaker and Trucklight's LED lamps are the only ones I've read about that seem to keep all the light in the acceptable zone. Within the lit area, there are visble patterns. "Hilldweller" did a bunch of semi-scientific comparisons with photos and light meter.
                  Jeepforum Headlight Shootout - Trucklite
                  Virgil is a consulting lighting engineer or something similar ... enough creds, I'd accept his comments about the Petersons being based on test results.
                  7 inch LED conversions
                • 65_Dart_GT
                  65_Dart_GT FABO Gold Member FABO Gold Member
                  106
                  30
                  Oct 24, 2007
                  Paris, ON, Canada
                  Local Time:
                  5:28 PM
                  Anyone know if I could do this with a stock 65 Dart GT?
                  • Like Like x 1
                  • BLKNBLU340DSTR
                    BLKNBLU340DSTR 1971 Duster 340 FABO Gold Member
                    149
                    96
                    Jun 8, 2017
                    Livermore,CA
                    Local Time:
                    2:28 PM
                    • Like Like x 3
