[SOLD] Left over 66-65 cuda exterior parts
dartin jack
Eastern Ontario
After finishing my restoration of 66 cuda these are some of my left over parts most are 66 & some are 65 as noted I prefer payment from usps international mo or paypal I send by post and the costs are yours but there are no packaging charges thanks fabo for the thread I have pics of all parts but cant shrink them to fit here so pls send e mail address and Ill send pics thanks dartin jack
4 66 headlight bezels $15 each1 pending
2 65-66 headlight bases $10 for both
1 65-66 headlight pot with 2 retainer rings $5
2 66 front bumper signal light pigtails $10 each
2 L & 1R 66 bumper signal light assemblies complete with lenses $20 each
2 66 rs fender signal light assemblies with good chrome & lights work $40 each
1 66 rs tailight assembly with lenses driver quality $40
1 66 tailight housing no lenses $20
1 66 tailight reverse housing only $5
2 66 bottom rs tailight lenses $5 each
1 66 bottom ls tailight lense $5
65 R & L complete tailight assemblies driver quality $80
66 front bumper horns $20 for the pair
65-66 trunk hinge $10
2 65-66 battery trays with support braces $20 each
2 tray support braces $5
2 66 hood safety latches $5 each
4 13" valiant hubcaps 2 good 2 have scrapes $10
2 13" sbp mag hub cap centers $10 valiant emblem
1 65-66 washer nozzle $5
2 L & R 65 forward inner fender splashshields need a little work @ bottom mounting $20 for both
1 LS 66 forward inner splash shield gc $15
65-66 full set of door hinges & mounting bolts $40
2 65-66 wiper transmissions & motors $20
3 65-66 door handle to latch (long)rods $5 for all
set of 2 66 spartan hi low horns $20
3 66 only rf rr & lr stainless wheel lip mouldings ls need work $40 for all
both rr & lr 65 stainless wheel lip mouldings $40
66 bumper jack mast jack assembly & hook no base $40
3 66 only rocker mouldings $20 each
4 66 rocker moulding mounting plastic clips $4
2 sets hood spring rods $10 each set
2 sets of rear window alum lock strip corners 1 with ribbing $25 the other smooth $20
full set drip rail stainless l &r sides $40
pair of 66 only top rear quarter trim (aluminum) $30 for the pair
2 pair 64-65 top rear quarter trim (stainless) $30 each pair 1 set pending
If you need anything else let me know as Im sure i forgot a few things, suprises me more than you thanks again dartin jack
sorry both rs housings pending,as you have first call on the complete lense that you have pics of let me know if its not what you want and Ill get the other parts to you when the mo arrives Regards John "now back on the block"
3 66 headlight bezels $10 each driver quality
66 front bumperettes $20 for the pair
1 65-66 battery tray with support braces $20 has been sandblasted
2 tray support braces $5 both sandblasted
2 sets of rear window alum lock strip corners 1 set with ribbing $25 the other smooth $20
1 pair 64-65 top rear quarter trim (stainless) $30
Update for removal of sold items thanks jack
Hello
You have a brake booster for barracuda 1966?
I hope your comments.
Thank yor
4 66 headlight bezels $15 for the good 1 & $10 each for the others
3 66 bottom rs tailight lenses $5 each
3 65-66 inner door handle to latch (long)rods $5 for all
2 sets of rear window alum lock strip corners 1 set with ribbing $25 the other set smooth $20
full set drip rail stainless l &r sides $20
66 only lower rad splash pan no rust or damage $20
thanks fabo
4 66 headlight bezels $25 for the very good 1 $30 for a driver set of l & r & $15 for the single drivers 1
1 65-66 battery tray with support braces(sandblasted) $20
2 battery tray support braces(sandblasted) $5
1 LS 66 forward inner splash shield gc(sandblasted) $15
1 65-66 wiper transmission & motor $20
1 pair 64-65 top rear quarter trim (stainless) $30 for the pair
remove sold parts thanks fabo
Is the last wiper motor still available? I need and want the wiper motor only.
