This is like sayin, "Ma'am, I caint date you. Your titties are just too big."
Lol,,,,,Yes you are right !
But if they are hanging down around her belly they won’t be any good to you .
Cams are a different animal,,,and are very important to the end result .
As the guy stated,,,he is interested in low and mid range power,,,,,that larger cam is not in that power range .
It will run just fine,,,,but at a different spot entirely .
The Purple shafts were made for a certain level,,,,and worked very well for what they were .
But the Magnum has some limitations,,,and,,,unless they are addressed,,,,might cause issues .
It’s an excellent engine,,,,just like the old 340,,,or 318 .
With the right combination,,,,they will fly !
The same is true for converter range,,,,,the wrong stall will make a very good engine seem like a Dog .
I just hope the Op chooses the right combination,,,otherwise he might be dissatisfied with the outcome.
The bigger cam will run great,,,,no dissent from me,,,,but it must be what he is really wanting .
And then all the other components have to match it too,,,and higher compression is a definite plus for the end results .
Tommy
