They ran 8.25’s in 1/2 ton 4 wheel drive trucks with factory 440’s in the late 70’s.
Well, the laughing was at they changed the name to 8 3/8... chuckle.... not at youThat is fine.
I don't know why you would actually laugh out loud about a rear axle but I do laugh at other things that you may find strange.
The 70 Charger standard axle was an 8 1/4" unit. Slant six, 318 and 383 2 barrel cars got this axle. The 383 4 barrel got the 8 3/4" axle.
I'd be surprised to see any C body with an 8 1/4" unit. Years of junkyard crawling and I've never seen one. If they were built, I have yet to see them.
Maybe the early 70s 360 Newports?
As far as vans, I admit that I'm not as familiar with their equipment since I've never owned one.
The trucks though. I've seen 8 1/4" axles in Dakotas, Durangos, D100 trucks but never a 4wd, never a 3/4 ton. If they were built, I've never seen one out here.
Actually.... the 440 didn't go away in '78. It hung around a while longer in RV'sI really doubt that. First, the 400 and 440 went away after 1978. EVERY 1/2 ton 440 truck that I have seen has had the 9 1/4" axle.
It's why I laughed...I thought the 8 3/8" designation was strange too.
WITH blocks that had casting dates no later than 1978.Actually.... the 440 didn't go away in '78. It hung around a while longer in RV's
The 8 3/8 designation "usually" meant sure grip.Well, the laughing was at they changed the name to 8 3/8... chuckle.... not at you![]()
which is odd in itself.. because our '80 D150 (drag truck) came with the "8 3/8", open rear and .... 2.71's !!!!The 8 3/8 designation "usually" meant sure grip.
GM did similar. Their 8.5" rear was called a 8.625" when it was a limited slip.which is odd in itself.. because our '80 D150 (drag truck) came with the "8 3/8", open rear and .... 2.71's !!!!
I figured the 2.71's must have been ordered, because 3.21 was the "run of the meal" for any D100/D150 2WDGM did similar. Their 8.5" rear was called a 8.625" when it was a limited slip.
What I highlighted is the bottom line. It was very, very reliable in all factory applications in which it was used. Even in the '73 340 Dusters with manuals.It is quite possible that I have not seen all of the oddball equipment that Chrysler stuffed into their cars and trucks.
The 8 1/4" axle was widely used and was a durable unit. I do try to refrain from stating absolutes, just that I have not seen them even though I've been junkyardin' and scrapping vehicles for a few years.
Holy crap, great information thank you.I ran an 8 1/4 in the 73 Scamp (my avatar) that I had for many years. Aftermarket 3.90 gears with an Auburn cone type sure grip. Factory axles. Factory cover. No bracing or anything. Car was not lightened at all.
It had multiple engine combinations. One was a mild 360 with a 100 shot of nitrous. 235/60/15 Mickey Thompson drag radials at the strip. Best time was in the 12.2s if memory serves. Lots of passes on that combo. Also ran a hotter 360 with better heads and no nitrous with the drag radials. I think that combo ran very low 13s. Never had a single problem with it. I sold the car to a guy I know several years ago and it's still going strong (he rarely races it - mostly street driven).
Your truck is obviously heavier than my Scamp so that is an additional factor. But overall I was very impressed with the 8 1/4.
Mine is in fact an 8-3/8” with factory 3:55s. Not a sure grip though unless it’s terribly worn out.Lets clarify, it's often called the 8 3/8 rear in trucks and such LOL
That's interesting. I wonder what designated the 8 3/8.Mine is in fact an 8-3/8” with factory 3:55s. Not a sure grip though unless it’s terribly worn out.
Me too, I’ve heard in a car it was an 8-1/4 and in a truck it was an 8-3/8. But they’re the same. Not sure how true that is.That's interesting. I wonder what designated the 8 3/8.
Maybe that's the difference.Me too, I’ve heard in a car it was an 8-1/4 and in a truck it was an 8-3/8. But they’re the same. Not sure how true that is.
I owned a 1977 1/2 ton 4WD with a factory 440 that had an 8.25 in it. Truck was all original. And I looked at another one that was ordered new that was very similar with an 8.25 in it. I, like you, was surprised there wasn’t an 8.75” in either of them. Ma Mopar did some weird stuff at times!!I really doubt that. First, the 400 and 440 went away after 1978. EVERY 1/2 ton 440 truck that I have seen has had the 9 1/4" axle.
