I went to the Indy swap meet yesterday and came home with some thing (s) I wasn't planning on.
I already have 2 360 magnum short blocks here that need gone thru, and I brought home a 3rd bare block. At least it has all the main caps and bolts. All block plugs freeze plugs and cam bearings are gone. So that plus being so clean tells me it has been thru the hot tank as he claimed.
Otherwise just a '96 block.
Completely bare, clean block.
The seller said that it's std bore and can stay that way. It definitely has absolutely no ring ridge. And no ridge reamer damage . Supposed to have been magnafluxed, definitely has been hot tanked. Story is it was for a customer that found a complete built motor after they got this one apart and was gonna wind up costing less than building this one up.
I didn't get any paperwork,(and I asked) that said it would be buildable at std bore nor that he was telling me the truth about it having been magnafluxed. (Could be it was magnafluxed and there was a problem?) I dunno but in a total of 3 visits to his sales spot I asked him what was the best he could do and he dropped his own price from 150 originally to $100. I took it at the $100...
But if I can put the ball home in and scuff the surface rust from storage off (really not that bad, rust is minor) put my dual bore gauge in and verify what he says I think I can save money by using this block vs one of the other ones I have. And get at least as good of a result. I do have another 360 mag crank rods and pistons in the shed that would complete the short block.
The one I have that I was gonna use was a failed build at 30 over that had like a couple of hours (no more than 4) on it on a fresh build. I'm sure I wouldn't have to bore that one anymore either and is usable at its current 30- over. Just dismantle and re clean everything, re replace the cam bearings (since i feel the need to send that one thru the hot tank again), not a big deal , new crank bearings, scuff and re replace the rings ( oil was a hell of a slurry when I drained the break in oil like I've never seen)
That one had at least a couple of injectors hang open and wash out the cylinders plus some valves stuck (1 bent) as I took EQ at their word that these heads were "ready to run out of the box". They weren't.
The other one is the original 260k mile short block out of my Durango. That short block has never been apart since brand new.
Whichever one I use I feel a need to die grind all the casting flash off of the oil return holes as all have some nasty barnacles around the oval holes above the cam... So all will need at least a quick splash in the hot tank..
I went back 2x after I originally talked to the seller and walked around and thought about whether I should have or shouldn't have bought that bare block...
