Rice Nuker
Burn tires daily
So, I want to use this to re-install rather than miscellaneous chains hooked on 4 points because that setup generally pissed me off during the pulling process.
Amazon.com: Mr. Gasket 33027G Engine Lift Plate: Automotive
according to the reviews, one person lifted a 400 Pontiac / 4 speed setup attached to an RPM intake. that seems similar to my weight. Pontiacs have heads made out of large boat anchors.
440 w 727, ac, ps, headers. Will be bolted to a performer intake. I will bolt to all 8 carb bolt holes on the intake if that helps. Not sure if structurally it would matter to the intake.
Any experience with pulling a whole setup with one of these intake mounted plates?
