Oh, as said earlier, a good solid cam and edm lifters.
Hard to beat.
Having a solid roller cam doesn’t Guarantee Jack!
Hard to beat.
Hard to beat.
YR your inbox is full
I am going to trash my Comp Hyd rollers and switch to solid rollers.
Would you please provide a supplier for a good solid retro fit roller.
340 LA, X ported heads, Comp roller top end with a Comp 20-811-9 cam, stock oiling system 25psi to 60psi hot. Street A body auto trans application.
Engine made 452hp corrected on a dyno.
If at all possible I would like to be able to remove lifters without removing the heads.
Thanks in advance
Sorry for the hijack
Didn't realize that rollers allow more aggressive cam profiles than FT.
They don't
so a roller would get the valve open to a useable lift quicker,
not usually
This mentality is why aftermarket companies don’t waste time on the Mopar crowd. You old guys just keep rocking those purple shaft cams and heaven forbid, don’t use anything from Comp Cams lol.
I get it but you guys are throwing around some big blanket statements based on personal bias. The people with experience know what you mean but those that don’t are taking it at face value.
I'm not that smart, but I totally understand what YR just said.
I have not had the years of experience, that he has had, and at my power level, have not come to those types of roadblocks; but I understand it none-the-less.
