1. mopardemon340
    mopardemon340 Well-Known Member
    547
    36
    Aug 10, 2015
    WI
    Local Time:
    12:48 PM
    looking to put a line lock in the car. what one do most people recommend and not have issues with.
  2. mderoy340
    mderoy340 Well-Known Member
    2,212
    968
    Aug 2, 2012
    Melbourne FL
    Local Time:
    1:48 PM
    • Like Like x 1
    • ValiantRacing
      ValiantRacing Well-Known Member
      385
      249
      Jun 12, 2009
      El Dorado Ca.
      Local Time:
      10:48 AM
      Biondo is the best, others leak
    • TrailBeast
      TrailBeast Slightly Twisted Member
      20,783
      7936
      Mar 11, 2011
      Arizona
      Local Time:
      10:48 AM
      BS.:D
      Some do, some don't, some that are not supposed to do, and some that usually suck are fine.
      I run the Hurst valve from Jegs.com and it works perfect.
      The button and light are kinda cheesy, so I used better ones.
      • Agree Agree x 1
      • SSG_Karg
        SSG_Karg Stuck in the middle
        1,152
        988
        Feb 24, 2010
        In the pits
        Local Time:
        1:48 PM
        The Hurst Roll Control has been on my Duster for 18 years with no problems/ no leaks.
        • Like Like x 1
        • mopardemon340
          547
          36
          Aug 10, 2015
          WI
          Local Time:
          12:48 PM
          I was looking at the Hurst. I just don't want anything to leak. That's my biggest concern.
        • 340Dart
          340Dart FABO Gold Member FABO Gold Member
          700
          81
          Jan 8, 2005
          Mount Morris, New York
          Local Time:
          6:48 PM
          I use the Biondo. Been in my car since the 90's. Still works great. No problems at all.
          Fred B
        • mopardemon340
          547
          36
          Aug 10, 2015
          WI
          Local Time:
          12:48 PM
          thank you everyone
        • Bad Sport
          Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
          37,224
          17649
          Jun 12, 2010
          The Wolverine
          Local Time:
          1:48 PM
          Hurst here as well, no issues.
        • halifaxhops
          halifaxhops It's going to get stupid around here! FABO Gold Member
          57,291
          25266
          Jan 20, 2014
          CENTRURAL, PA
          Local Time:
          11:33 PM
          Biondo, no issues in my dart
        • famous bob
          famous bob mopar misfit FABO Gold Member
          15,439
          5590
          Aug 14, 2011
          okla
          Local Time:
          12:48 PM
          jegs version, summits brand, tci and b-m, never had a problem w/ any of them.
          • Like Like x 1
          • Kiddart1
            Kiddart1 Well-Known Member
            126
            36
            Aug 27, 2008
            Macomb Michigan
            Local Time:
            1:48 PM
            I run the Jegs brand, switched from Hurst a few years back due to lost pressure. I can hold the front brakes for ever with the Jegs. as mentioned above some leak down some don't. If you are worried about actual fluid leaks that all on the installation and what you use.
            • Like Like x 1
            • Jack Mosby
              Jack Mosby New Member
              2
              0
              Sep 12, 2018
              Post Falls, Idaho
              Local Time:
              10:48 AM
            • dodgedifferent2
              dodgedifferent2 Well-Known Member
              2,503
              331
              Aug 8, 2008
              southwestern, Ontario
              Local Time:
              12:48 PM
              I have the hurst
              Use the correct fittings and no issues to be had.
            • straightlinespeed
              straightlinespeed Sometimes I pretend to be normal Staff Member FABO Gold Member
              9,862
              3184
              Oct 21, 2012
              Oakdale, MN
              Local Time:
              12:48 PM
              I've got the Summit brand and no problems at all. I dont use it regularly, but its held up great so far.
            • Syleng1
              Syleng1 Karma is real and Life is short... FABO Gold Member
              1,357
              937
              Jul 5, 2005
              North Franklin, CT
              Local Time:
              1:48 PM
              After years of racing on and off the track most are all good as long as you flair the tubing properly and use good quality brass fittings and steel tube nuts. No compression fittings and basically “low pressure” means a leak or low voltage. The electrical coils used to open the valve or hold the valve get hot when energized and draw more power. If the power is not there then the magnet drops holding and the valve seeps fluid by or shuts down all together. They are used for heating up the rear tires (30-45 sec) not as a parking brake.
              Good luck as I am putting one on my 66’ as I type this. I went Hurst.
              Joe
            • grimreaper
              grimreaper Cross Member
              3,492
              684
              Jul 8, 2005
              Gillette, WY
              Local Time:
              11:48 AM
              Hurst roll control on two of my cars. No issues whatsoever.
