Mopower71
Speed Demon
Went to a local cruise last night,
Had a good time, talked to a few people.
Demon is leaking a small amount of anti freeze from the thermostat housing. It is a new one, thicker base, and the dang thing still leaks.
It's also leaking a bit of oil, drips on the oil pan, on the k frame, and back towards the transmission.
Also, the right rear tire is rubbing the fender, and is peeling rubber off. It is closer to the top on the right side than on the left. Sounds bad when I go over a bump. Then you can smell the burnt rubber in the car. I did just fill the fuel tank up full for the first time, So, all the weight from the fuel, plus the 3 kids in the back make it sit lower. I'll have to swap out one of the leaves on the passenger side, for a better one.
I also know where a bunch of Dusters ended up. More Mopars at the cruise than anything else.
