Looking for a Denso alternator with single V belt
rustytoolss
Clinton, Ohio
Need a small alternator (say 90amp) . What year, make,model will fit a small block mopar ? with single V belt. Oh also external regulator type.
1988 Diplomat, but all I see are double V pulley, but you could swap that to a single. The Toyota ones I see recommended are internally regulated unless someone knows of one that isn't.
ar eng says denso 210-0106. he also has the plugin for it and can probably give you instructions on how he wants to hook it up. also has the bracket.
