Looking for a radiator shroud
nitronut
I'm looking for a radiator shroud for a '69 plymouth radiator #2949072 automatic. There's also another # on the radiator 38086 Any ideas where to find one. Already looked at Mancinis and Classic Industries with no luck.
68-69 are not reproduced. 70-72 won't fit. Lower hose is on the opposite side. They are out there but they sell for double of the 70-72 repops cost. Usually $400 - $500 for a nice clean one with no cracks. I have both if you need pictures to compare the two.
Not sure your setup here?
I upgraded to a 6 blade mopar clutch fan from a 4 blade solid mount in my stock '69 318, without a shroud.
'69 Satellite 318 with the cast iron water pump, automatic, with external transmission oil cooler.
External trans oil cooler may help your stock cooling system to extract more heat, then it is not fighting the tranny heat too.
Just a thought.....
Noticable difference in keeping the engine cool on hot days.
I bought my Fan Shroud from Restoration Parts Source for my 340 Duster and it fits perfectly with no mods needed. Total cost was 168.95 including shipping.
