Looking for advice on wheel well carpet on fastback
Bud27
West LA
Carpet kit for 65 barracuda has wheel well covers can't get them to lay flat . Any advice is welcomed and thanks.
I haven't done mine yet, but the advise I had was to spray an adhesive to the surface and apply the carpet. Let me know how you get this to work.
After reading some other thoughts, someone said to lay the carpet out in the sun and let it get hot and it would form better. Others said use heat to help it conform.
Used dap weldwood red can only . Brushed both sides carpet and wheel well . Let it get tacky and start applying carpet . Make sure you pre cut to the finished measurement profit before brushing contact cement .
Yes ,let sit in sun or heat it up . Apply heat gun for final placement and let it dry . The cut have to be pretty prisice if not you get bubbles . Patients is everything . The rest of the car was a breeze . Post pics when I finish . Hope this helps .
