Looking for Automotive Wiring Tech in Dallas TX
Heywodja
The Heartbeat Stops Here
Texas
Is there anyone in the Dallas Area who does updated electric re-wiring in the Dallas area?
TIA
How extensive is the wiring project? I have a friend in Princeton who may be able to help you out. I'll try to call him once you can tell me how extensive it is. PM me, that way it will show up on my phone.
I am considering a complete re-wire..
A total rewire of what car? I need more information, i.e. year, engine, transmission & anything else that you can provide.
1972 Dart Swinger 2 door...
Another blah blah blah build...
My engine compartment has been mostly smoothed out so, I want the wiring minimal in the engine compartment.
  1. Battery relocation to trunk. (I have cracked back working on some nice cables.)
  2. I will be running a small block with an in-tank fuel pump and Edelbrock Pro flow 4 EFI, with a ready to run distributor that came with the package.
  3. Rear taillights, blinkers, trunk light and License plate light. I have a stock replacement harness from M&H
  4. Side markers are shaved on all 4 corners, so no need for those.
  5. Front is LED headlights, with stock plugs, stock turn signals in the grille, and stock fender mount turn signals.
  6. Dual electric fans on an aluminum aftermarket radiator. I have some relays for the fans.
  7. 904 Auto trans with Reverse manual valve body and a lock up torque converter, so I will need a momentary switch for the neutral safety start and an on off for the torque converter. I am using an SCS cheetah shifter.
  8. Interior is stock gauges, would like to bypass the ammeter in favor of a voltmeter. Door light switches, head lamp and high beam switch, dome light and a heater.
