Looking for shumacher mounts and
grassy
Nova Scotia
...haven't been lucky...would like new ...or almost..for /6 to 360..for a '75 Duster.
..and a cable (4 or 5 foot) and a connector to an a727 for a B&M pro rachet shifter...
Getting close to d-day..the start of the rebuild..
Ian.
I believe Summit sells mounts made by Trans-dapt or someone that are cheaper than Schumacher. Might check out there web site.
..moving to a 360..
Wil check out other mounts..
..pulling everything off and flipping car...would consider a K frame but so expensive to ship..and would it be as good as the mounts..?
Tanx
Ian.
No need to change the K-frame.Summit sells the engine mounts for swap(trans-dapt)or you can go the Schumacher route $$.I used the Schumacher ones going from 6 cyl to V8(410)in my race car.You should look for some new(bigger)torsion bars also.JMO
