Looking for some to set up a 3rd member. Recommendations?
Mid-West
  1. Divenut
    Divenut Well-Known Member
    2,897
    1092
    Sep 22, 2011
    Naperville Illinois
    Local Time:
    4:00 PM
    Hey Folks,
    Moving the Duster project along slow but sure. I'm now to the point where I am ready/need to tend to the rear end. Currently a peg leg 742 w/3.23's, going to a Suregrip unit (Dr Diff) and 3.91-4.11's. I should have no problem getting the center section out and back in once it's built, but I am pretty much clueless when it comes to setting up differentials. So I will need to have someone, or a shop, in the area do the set-up for me.
    Anyone have any recommendations for a place in the suburbs of Chicago? Hoping to chat with and line up someplace up before I get the parts.
    Thanks all,
    Pat
    • Like Like x 1
    • BigBlockMopar
      BigBlockMopar BigBlockMember
      1,711
      707
      May 1, 2011
      Netherlands
      Local Time:
      11:00 PM
      I would find an empty housing and just build a second unit and keep the current 3.23 as a spare.
      • Thanks! Thanks! x 2
      • Agree Agree x 1
      • retroron
        retroron FABO Gold Member FABO Gold Member
        694
        516
        Apr 9, 2014
        Livermore Calif
        Local Time:
        2:00 PM
        Start with a 489 case
        • Disagree Disagree x 1
        • JBurch
          JBurch Well-Known Member
          1,750
          857
          Oct 17, 2009
          Owego, NY
          Local Time:
          5:00 PM
          IF..........you go with a 489 housing..get a crush sleave eliminator spacer
          • Agree Agree x 2
          • Alaskan_TA
            Alaskan_TA Well-Known Member
            4,887
            2856
            Nov 12, 2004
            PA
            Local Time:
            5:00 PM
            Nothing wrong with a 741 or 742 case.
            • Agree Agree x 4
            • Like Like x 1
            • JBurch
              1,750
              857
              Oct 17, 2009
              Owego, NY
              Local Time:
              5:00 PM
              I agree............my 4.88's are in a 741, my 4.56's are in a 742
              • Thanks! Thanks! x 1
              • Alaskan_TA
                4,887
                2856
                Nov 12, 2004
                PA
                Local Time:
                5:00 PM
                • Like Like x 1
                • SGBARRACUDA
                  SGBARRACUDA ROY FABO Gold Member
                  14,938
                  4387
                  Dec 7, 2006
                  PLANT CITY FL. and PERRY GA.
                  Local Time:
                  5:00 PM
                  I hope this doesn't derail into a 489,741,742 debate, as usually happens. I agree locate a second third member and keep your original in tact.
                  • MD68
                    MD68 Well-Known Member
                    102
                    96
                    Aug 15, 2016
                    Indiana
                    Local Time:
                    4:00 PM
                    I'll PM you the name of a guy.
                    • Divenut
                      2,897
                      1092
                      Sep 22, 2011
                      Naperville Illinois
                      Local Time:
                      4:00 PM
                      Thanks folks. Good call on finding another chunk to have built and keep the 3.23 chunk intact.
                      MD68 - I got your message. Thanks again!
                      Be well folks,
                      Pat
                    • fishy68
                      fishy68 Tyr Fryr's Inc. FABO Gold Member
                      16,822
                      825
                      Jan 11, 2005
                      Central, IL (Hooterville)
                      Local Time:
                      4:00 PM
                      Why?
                      • Agree Agree x 1
                      • retroron
                        694
                        516
                        Apr 9, 2014
                        Livermore Calif
                        Local Time:
                        2:00 PM
                        It’s designed to handle high horsepower
                        • fishy68
                          16,822
                          825
                          Jan 11, 2005
                          Local Time:
                          4:00 PM
                          That's debatable IMO but I won't go any farther because I don't want to get the OP's thread off track. PM me sometime if you'd like to discuss it. Tracy
                          • Agree Agree x 1
                          • Jadaharabi
                            Jadaharabi FABO Gold Member FABO Gold Member
                            5,689
                            5624
                            Jan 8, 2016
                            Peoria, Illinois
                            Local Time:
                            4:00 PM
                            Because some people think it is rhe strongest of rhe three.
                            However I perfer the 742 because it has the biggest inner pinion bearing of the three and does not use a crush sleave.
                            Having said that, any of the three will work just fine.
                            If you put a crush sleave eliminator in the 489 it is a lot better. I have had the crush sleave split with 4.88s and a 340 turning it.
                            • Agree Agree x 1
                            • j par
                              j par Well-hung Member
                              15,681
                              7541
                              Jul 2, 2014
                              Portland Oregon
                              Local Time:
                              2:00 PM
                              Yeah it would be nice to get past the arguments over the questions you didn't ask lol obviously you've already bought the part so this is what you're going to do. this is your hobby you can either pay someone to do it or learn to do it yourself. It's not rocket science they've been doing it for 50 years or more. I'm sure you'll need a tool and I'm sure someone needs done it a million times can do it quick. Myself I've seen it done and I've had it done and the next time I'm just doing it myself from here on out. I'm tired of paying people 150 to $250 for which should only take an hour or so beyond the normal hooking everything else up that's straightforward.
                              My experience is I bought a 489 case and put brand new gears with a spool set up by a professional with the crush sleeve Eliminator kit and in less than 20 passes on the dragstrip blew the Caps off the back LOL I have a Dana now.
                              • Like Like x 1
                              • Divenut
                                2,897
                                1092
                                Sep 22, 2011
                                Naperville Illinois
                                Local Time:
                                4:00 PM
                                Ya, I'd loved to learn how to do it myself. The challenge is finding someone in the area to walk me through it. I have decided to go the route of keeping my 3.23 chunk as it is, and find another 742 to set up. Not in a big hurry as I plan on doing a front disk brake conversion next. Been focusing all my time getting the car to accelerate nicely. Now that it is, the "The Boss" made me promise to ditch the front drum set up after a few romps around town. After 29 years of marriage, I've come to appreciate her subtle suggestions!
                                Pat
                                • Agree Agree x 1
