Looking for stuff to complete my 440/727 combo
daves66valiant
68 Dart 340/727:66 Signet Vert 340/5spd: 68 D100
SoCal
Looking for stuff to complete my 440/727 combo for the new '68 truck I just got. Need a few things
-440/727 tranny kickdown assembly
-440 manifolds. Not sure if my 440 headers will work in the truck
-Alternator bracket
-1968 383 or 440 engine mounts/brackets
-Dual plane Edelbrock alum intake
-water pump pulley and crank pulley. No power steering and non AC.
That should do it for now I think
I did a similar swap in a 69 swb 2wd. I do have the throttle cable bracket, kick-down linkage, mount brackets, crank and waterpump pulleys, alt brackets and adjusting arm. I used b-body headers, they cleared the frame rails by 2 inches. Do you have the rear sump oil pan and pick-up tube? I do have the right pan if you want to go that route. I will check, but I should have the metal fan shroud also. I used the solid fan with a fan spacer from a early newport. I went with the truck 4-speed and really surprized some chevy dudes. pm me if you still need this stuff.
