Durney
A-Body parts list-
Most parts are from a 73/74 Duster but obviously much is interchangeable. Some is mint some is driver quality. List is PARTIAL as there is more that ALL goes...look at the pics for more stuff!
Prefer to sell the following parts together at a heavily discounted price and have someone PICK IT UP. I'm in Michigan ( west of Port Huron)
As far as pricing.... I looked at many of the same stuff here and on ebay and let's do this, the columns, power steering, and shift handle ALONE are worth $700. So that's the price and the rest is free.
Will post photos shortly
Tuff Wheel Center cap - Mint
Complete power steering kit (Steering gear w/ pitman, Pump and reservoir, NEW engine bracket set
1973 Grille (nice)
73 Headlight bezels (excellent)
Headlight retainers - pair (buckets)
New MOOG K3180 (pair)
Black kick panels Pair (with 5" speakers)
Heater blower switch (tested and includes panel)
Wiper switches (3) (one multi-speed with resistor and two std)
2 -dash shells one has column brace removed the other has a good CORE pad
OEM Under dash AC vent outlets with good vents
AC/Heater dash control - MINT
Wiper pivots, and trans arms set
2-Steering columns both good shape and complete, both floor shift
Lower column cover - excellent
Pair weatherstrip moldings -nice (where the main window strip attaches)
Foot pump washer with mount - Good
Washer squirters and brackets
Washer reservoir (no cracks)
Pair Black sunvisors - good (no hdwe)
Sport mirror (needs glass but metal is perfect)
Brake set - all were new undriven but on the car when purchased (Rear drums, Shoes, Fr pads, NEW hdwe kit)
Proportioning valves (3) One original, One repop like new, and one NEW still in box
3 Tailight bezels - all nice and all have full studs intact (one has minor pitting)
4 Steering wheels - One 70's Mopar truck, One Deluxe (no cover), one std a-body, one Wood rim/chrome
Pair NEW Black lock knobs
Bayonet style Chrome shifter handle - MINT (typical a-body shape)
Pair defrost vents (typical stud damage but useable)
318 style air cleaner - nice
Wiper motor / resistor / harness (2-speed)
Sill plate (single) nice
Pair front fenders 73 Duster) both need work but salvageable
5 side marker lights (2 have minor crack)
Manual brake pedal
Pair (L&R) Tailight housings
Rear armrest bases - pair
several sets of Fuel tank straps with correct j-bolts
Complete sway bar bushing brackets with hdwe
Set of complete E-brake cables, brackets, links, rear cables, hdwe
Rear spring perch set with shock mounts
Full box of misc seat belts / retractors
3 Glove box doors with deluxe covers, locks, and hinges, and latches
2 Complete Instrument panels with Speedo, gauges, bezels
2 complete ash tray sets with dash mounts
2 Complete under dash wiring harnesses, fuse panels and misc engine harnesses
Battery tray _ solid
NEW complete Body plug kit
New set window rollers
Several boxes of hard to find hdwe (large fender bolts, ferrule nuts, new hose spring clamps, etc etc)
Full set of 14" Slot mags (14x8 and 14x7) Rears have a nice set of 245/60 radials on them
1973 Grille (nice)
Manual brake pedal
