1. Dennis Gerard
    Dennis Gerard Well-Known Member
    208
    44
    May 7, 2017
    Florida/tenn
    Local Time:
    4:18 PM
    Question of the day! my 68 barracuda hits or grounds out on speed bumps on the front end running stock 14" tires any ideas left side is lower then right...
  2. abodyjoe
    abodyjoe Well-Known Member
    19,367
    3571
    May 22, 2004
    Berlin,N.J. 08009
    Local Time:
    4:18 PM
    can turn the torsion bars up some
    better shocks
    larger torsion bars and better shocks...
    • Like Like x 2
    • Dennis Gerard
      208
      44
      May 7, 2017
      Florida/tenn
      Local Time:
      4:18 PM
      I put new heavy duty shocks on today...
    • toolmanmike
      toolmanmike FABO Staff Staff Member FABO Gold Member
      35,217
      17194
      Jan 18, 2006
      Iowa
      Local Time:
      3:18 PM
      Can you post a side shot photo so we can see where it's at?
    • Dennis Gerard
      208
      44
      May 7, 2017
      Florida/tenn
      Local Time:
      4:18 PM
      can do tomorrow, left side is lower then right side
    • cosgig
      cosgig MoBro Inc. FABO Gold Member
      10,785
      3181
      Jul 20, 2008
      Pinckney, Michigan
      Local Time:
      3:18 PM
      Better get under there and pre lube those adjuster bolts!!
      • Agree Agree x 2
      • Like Like x 1
      • Bodyperson
        Bodyperson A little sketchy
        1,840
        1580
        Nov 26, 2015
        NW MONTANA
        Local Time:
        2:18 PM
        Any noise? Like CLUNK. Probably not or you would have said so.
      • toolmanmike
        35,217
        17194
        Jan 18, 2006
        Iowa
        Local Time:
        3:18 PM
        And jack it up and take the weight off.
        • Agree Agree x 2
        • Like Like x 1
        • RustyRatRod
          RustyRatRod 30 Degrees Outta Whack FABO Gold Member
          47,983
          13359
          Jun 7, 2010
          Georgia
          Local Time:
          4:18 PM
          Shocks haven't a thing to do with ride height. A good shock will keep the car from bottoming during jounce, though. If it's too low, raise it up. Pretty simple.
          • Like Like x 1
          • Agree Agree x 1
          • Locomotion
            Locomotion Well-Known Member
            2,694
            249
            May 31, 2004
            Florida
            Local Time:
            4:18 PM
            May have to get a front end alignment after any changes in ride height. Good time to check the rest of the suspension & steering parts before an alignment as well.
          • TrailBeast
            TrailBeast Slightly Twisted Member
            19,223
            5564
            Mar 11, 2011
            Arizona
            Local Time:
            2:18 PM
            The streets in my area suck as far as dips, bumps and uneven surfaces go, and I had the same problems until I installed 1.03 torsion bars and single chamber shocks.
            The bars themselves helped to get the front end up a little more as well as not compressing so easily, and the shocks helped with front end dive.
            Still I make an effort to avoid speed bumps if I can, and If I do have to deal with them I ease the front end down off of them to limit the compression of the suspension.
            The guy in the SUV behind me can just wait.:D
            • Agree Agree x 2
            • Dennis Gerard
              208
              44
              May 7, 2017
              Florida/tenn
              Local Time:
              4:18 PM
              • Agree Agree x 1
              • Dennis Gerard
                208
                44
                May 7, 2017
                Florida/tenn
                Local Time:
                4:18 PM
                pictures posted
              • AJ/FormS
                AJ/FormS 367 FormS clone 3.09-1.92-1.40-1.09-.78od 3.55s FABO Gold Member
                15,004
                4148
                Jan 19, 2014
                South-Central Manitoba,Canada, 900ftelevation
                Local Time:
                3:18 PM
                1.03bars and HD shocks.
                I hammer over speed bumps on purpose everytime I see a tuner car crabbing over one,
                BaBAM-BaBam
                !! I like to think I'm getting air,lol.
              • Dennis Gerard
                208
                44
                May 7, 2017
                Florida/tenn
                Local Time:
                4:18 PM
              • Dennis Gerard
                208
                44
                May 7, 2017
                Florida/tenn
                Local Time:
                4:18 PM
                Went out today and jacked up the car was going to try to adjust the torsion bars, but here's what I found...
              • abodyjoe
                19,367
                3571
                May 22, 2004
                Berlin,N.J. 08009
                Local Time:
                4:18 PM
                thats a problem.. :)
              • Locomotion
                2,694
                249
                May 31, 2004
                Florida
                Local Time:
                4:18 PM
                Try to look on the bright side......you have a good start on rebuilding the front suspension. (Other side & other parts have just as many miles on them.) At least it wasn't a rusted/twisted mount in the crossmember.
              • toolmanmike
                35,217
                17194
                Jan 18, 2006
                Iowa
                Local Time:
                3:18 PM
              • rustyfish
                rustyfish Well-Known Member
                512
                309
                Sep 15, 2015
                Kansas City
                Local Time:
                3:18 PM
                Oh Snap!
                • Like Like x 1
                • DrCharles
                  DrCharles Well-Known Member
                  438
                  156
                  Jun 7, 2012
                  West Plains, Mo.
                  Local Time:
                  3:18 PM
                  ^ I see what you did there... :p
                  Check out PST torsion bars, I believe you get a discount for being a FABO member:thumbsup:
                • Dennis Gerard
                  208
                  44
                  May 7, 2017
                  Florida/tenn
                  Local Time:
                  4:18 PM
                  Got my new 1.03 torsion bars, and installed the left once but it made no different in the way the car sets did I screw up installing them
                • abodyjoe
                  19,367
                  3571
                  May 22, 2004
                  Berlin,N.J. 08009
                  Local Time:
                  4:18 PM
                  install both of them and adjust accordingly. did you install it correctly? if the car sits low like that then the torsion bar mounts in the crossmember are probably rotted and spinning...
                  • Agree Agree x 1
                  • Dennis Gerard
                    208
                    44
                    May 7, 2017
                    Florida/tenn
                    Local Time:
                    4:18 PM
                    west coast car not much rust on underside
                  • abodyjoe
                    19,367
                    3571
                    May 22, 2004
                    Berlin,N.J. 08009
                    Local Time:
                    4:18 PM
                    are both new bars in or only one??
                    sure they are installed correctly?
