Low fuel pressure with new fuel pump
Fuel and Air Systems
  1. Markzilla88
    Markzilla88 Active Member
    30
    10
    Oct 4, 2019
    Maryland
    Local Time:
    1:14 PM
    hey guys, I’m banging my head against a wall on this one and need some advice and guidance.. The car is a 72 demon with a 360. I just installed a new Holley red pump (to replace the current Edelbrock small pump mounted improperly and not flowing well enough) behind the fuel tank, at the same level as the bottom of the tank. I’ve got an inline filter before the pump facing the right direction. All brand new 3/8” hoses and lines to and from the fuel pump are going the right way. I have the line running to another fuel filter in the engine compartment, then to a regulator, then to a fuel pressure gauge, then to the carb (Edelbrock 1405). Once started it only has 2 lbs of pressure. The pre filter before the fuel pump gets sucked almost completely dry. Positioning that filter only helps slightly with increasing the levels of fuel in it. The filter in the engine bay fills to about 1/4 full but after revving the engine some it’s almost empty. The gauge then reads 0, but the car continues to idle.
    I went ahead and bypassed the regulator to see what I was getting from the pump. It holds at a steady 3 lbs of pressure, but the pre filter again runs low (doesn’t ever fill completely up) and the engine bay filter runs about at the same levels.
    What gives?????? I made these changes to a bigger pump to give me significantly more fuel pressure! Not less
    Any guidance would help greatly
  2. mderoy340
    mderoy340 Well-Known Member
    2,209
    965
    Aug 2, 2012
    Melbourne FL
    Local Time:
    1:14 PM
    Pulling fuel up and out of the tank does not work. The pump needs to be gravity fed.
    • Agree Agree x 1
    • dano
      dano Evil Handy Man
      2,810
      810
      Aug 22, 2005
      Gresham, Oregon
      Local Time:
      10:14 AM
      So the pump is equal too or higher than the tank?
    • plumkrazee70
      plumkrazee70 FABO Gold Member FABO Gold Member
      2,402
      644
      May 5, 2013
      Medford, Oregon
      Local Time:
      12:14 PM
      His first post said "behind the fuel tank, at the same level as the bottom of the tank"
    • plumkrazee70
      2,402
      644
      May 5, 2013
      Medford, Oregon
      Local Time:
      12:14 PM
      Where is your pump actually located? All of the external pumps I have seen have been on the frame rail.
    • Markzilla88
      30
      10
      Oct 4, 2019
      Maryland
      Local Time:
      1:14 PM
      It won’t fit anywhere in the frame rail, and more on that is I couldnt get it below the tank. It’s mounted off the spare tire well from the trunk. It’s behind the tank, but equal to the bottom of the tank. I mean I understand it’s not good at pulling, but the way the sending unit is mounted in the tank, the gas line is pointing upwards. That’s the only pull it would have to do. I’ll try to post a picture of the pump for a better idea.
    • MOPAROFFICIAL
      MOPAROFFICIAL Well-Known Member
      5,030
      4008
      Jun 1, 2016
      Beach
      Local Time:
      10:14 AM
      Correct. They are pushers, not pullers.
      Frame mount it lower, also the red pump doesn't need a regulator...and chances are the regulator he is using is a pos " in line chrome dial type from parts store performance section" that no matter where you set them...they put out 2.5 or so... garbage.
      @Markzilla88
      OP should mount it pass side at wheel well bend on frame, or make a plate to mount it.
      Bout the only place it fits.
    • 1994redram
      1994redram FABO Gold Member FABO Gold Member
      1,201
      633
      May 9, 2012
      Oklahoma
      Local Time:
      12:14 PM
      I have my electric pump mounted on the frame rail at the highest point, above the axle. The regulator is a cheap Mr gasket dial type. I haven't had an issue with it in several thousand miles. It pulls fuel from the factory tank just fine. I have adjusted the pressure from 4-6.5 for sh!+$ and giggles.
      • Like Like x 1
      • Markzilla88
        30
        10
        Oct 4, 2019
        Maryland
        Local Time:
        1:14 PM
        I guess I can try to mount it up there. It’ll certainly be higher then the tank.. the previous owner had an Edelbrock 38gph pump mounted high, and it never made good enough pressure while driving. He says the motor needs to run at 6lbs or else it’ll lean the motor out and ruin it.
        I did bypass the regulator when I put the holley red on there, but still made max 6.5 lbs and then it dropped to 5 after driving it up and down the street twice so I parked it.
      • MOPAROFFICIAL
        5,030
        4008
        Jun 1, 2016
        Beach
        Local Time:
        10:14 AM
        My '71 swinger had enough room to mount on the frame just before the wheel well, that's forward of the axle
      • MOPAROFFICIAL
        5,030
        4008
        Jun 1, 2016
        Beach
        Local Time:
        10:14 AM
        Put a gauge on it and report back.
        I don't lie or make things up. Most people never know how bad they are because they dont even have a pressure gauge to know...and an engine will run on very low pressure, it's only sustained high power loads does the lack of psi show its ugly face.
        To the OP, red pump doesn't need a regulator.
      • Markzilla88
        30
        10
        Oct 4, 2019
        Maryland
        Local Time:
        1:14 PM
        So theres space issues with mounting it anywhere near the rear axel. It’s an 8 3/4 which is beefier then I imagined it would be. But Behind the axel is the gas tank and air shocks. And in front of the axel theres the dual 3” exhaust tips that end right before the rear axel. There really is no room for it up there I don’t think.
      • Markzilla88
        30
        10
        Oct 4, 2019
        Maryland
        Local Time:
        1:14 PM
        I think I may try dropping the tank and inspecting the sending unit. Possibly the sock has come off or is clogging the line. That’s the only thing I haven’t gone in and inspected.
        • Agree Agree x 1
        • 512Stroker
          512Stroker We are all here because we are not all there.
          1,088
          763
          May 30, 2016
          Freedom, MO
          Local Time:
          12:14 PM
          Try deleting the filter on the inlet side of the pump. I have had several Holley pumps w/o issues never ran a filter on the pump inlet
        • 1994redram
          1,201
          633
          May 9, 2012
          Oklahoma
          Local Time:
          12:14 PM
          I have a gauge installed. I went 12.80s on a very mild 360 in my dart at 3310 pounds plus driver. It seemed to work just fine. I now have an aluminum head 408 with a bigger cam and I expect to possibly have some fuel issues when I finally get around to tuning it and driving it hard.
          Never called you a liar, merely stating how MY car is setup. It works for me.
        • pishta
          pishta I know I'm right....
          16,509
          6197
          Oct 13, 2004
          Tustin, CA
          Local Time:
          10:14 AM
          Where is the air pocket coming from in the pre filter? Can you 'burp' it by tilting it up and letting the air bubble go up the line? Air is compressible, but should not knock it down to 3.
          "Installation Note: Should be mounted below the fuel level of the tank for a good gravity feed on the inlet side.
          • For street performance applications
          • Free-flow capacity of 97 gallons per hour / 367 liters per hour
          • Flows 71 gallons per hour maintaining 4 psi line pressure
          • Pressure is pre-set at 7 psi (approximately)
          • Maximum pressure is 7 psi
          • Pressure regulator not required
          Pre pump filter should be a 100 micron, fuel filter at carb should be ~10 micron. These gerotor type pumps can handle particulate well.
        • George Jets
          George Jets 1967 Dart 2 Door FABO Gold Member
          1,890
          2660
          Jan 18, 2019
          Farmington MN
          Local Time:
          12:14 PM
          Had the same low pressure issues with this new Holley electric fuel pump, put this brand new one on to replace the same.
          Like 3 psi, cheep electric pump. Going back to manual stock fuel pump when time allows.
          • Like Like x 1
          • 67Dart273
            67Dart273 FABO Gold Member FABO Gold Member
            41,743
            9408
            Oct 14, 2010
            Idaho
            Local Time:
            10:14 AM
            I had a red pump mounted above the tank up by the shock towers. Worked just great. He has a bad pump, or a restriction. Fuel sock, strainer, whatever Or it's not getting enough power
            • Agree Agree x 1
            • Markzilla88
              30
              10
              Oct 4, 2019
              Maryland
              Local Time:
              1:14 PM
              I threw on a holley blue and it’s making tons of pressure. Had to regulate it down to 6.5 lbs but it was initially making 12. I think I’ll still drop the tank and clean/remove that sock when I can but so far I’m happy. I was able to take it for a ride and have it not leave me stranded
              • Like Like x 1
