Low Mileage Hydraulic roller 360 LA and $1000.00- what would you mod?
Small Block Mopar Engine
  1. SLOPAR72
    SLOPAR72 Well-Known Member
    1,291
    583
    Jan 5, 2016
    Richmond, VA.
    Local Time:
    1:03 AM
    I am taking on a small project for someone. Low mileage 89 360 out of a truck. He is dropping it off and 1000.00. Motor runs great but want some performance increase but it will be a daily beater and will retain HP Exhaust manifolds which he has now.... Fuel management is a Holley Snipe and MSD ignition.
    The only other thing he is bringing is a set of low mileage 915's done about 10 years ago.
    So what would you change? If he sees anything near 300hp it will exceed his goals....
    JW
  2. Willyrd
    Willyrd Well-Known Member
    150
    67
    Apr 16, 2018
    Southwest Ohio
    Local Time:
    1:03 AM
    Cam is usually a good start. I'd keep the LSA above 108 and the lift around .500 or below. Port and polish, with some springs goes a long way for heads. Aluminum dual plane intake will help keep it streetable and it'll lighten up the motor quite a bit. Oh and a 700 dollar cold air intake filter goes with out saying.
    • Like Like x 2
    • SLOPAR72
      1,291
      583
      Jan 5, 2016
      Richmond, VA.
      Local Time:
      1:03 AM
      I am curious as to if he will be better off with the 915's.... I have some time to research it to see what I come up with... As for the cam, the LSA will be pretty wide with the fuel injection which is OK as he doesn't need a firebreather lol....
      And where did you find a Cold Air setup for under 1000.00 lol....
      JW
      • Like Like x 1
      • Jadaharabi
        Jadaharabi FABO Gold Member FABO Gold Member
        3,931
        3380
        Jan 8, 2016
        Peoria, Illinois
        Local Time:
        12:03 AM
        89 roller motor should have 308 heads. If never overheated they should be crack free. Depending on the work done to the 915s you may have 2 decent sets of heads to work with.
        Cam it, a little head work along with an intake and sniper. I think 350 hp imho.
        • Like Like x 1
        • Agree Agree x 1
        • TrailBeast
          TrailBeast Slightly Twisted Member
          19,232
          5579
          Mar 11, 2011
          Arizona
          Local Time:
          11:03 PM
          Cam, valves and head work.
          • Like Like x 3
          • dusted
            dusted FABO Gold Member FABO Gold Member
            279
            215
            Sep 24, 2006
            Creedmoor, NC
            Local Time:
            1:03 AM
            Turbo!! But that’s just me!! Haha, Jk....
            • Like Like x 2
            • Wyrmrider
              Wyrmrider Well-Known Member
              915
              295
              Sep 5, 2016
              los angeles
              Local Time:
              10:03 PM
              KB pistons get the compression up piston open/ closed head dependent
              just a multi angle valve job and blend the bowls
              i would not put in a longer cam with low compression in a truck
              • Like Like x 1
              • RustyRatRod
                RustyRatRod 30 Degrees Outta Whack FABO Gold Member
                48,048
                13419
                Jun 7, 2010
                Georgia
                Local Time:
                1:03 AM
                He'll have 300 plus HP just bolting headers on.
                • Like Like x 1
                • rumblefish360
                  rumblefish360 so close yet so far away
                  33,457
                  5525
                  Jun 21, 2005
                  New York, on a Island
                  Local Time:
                  1:03 AM
                  Shop the classifieds for a good carb and cross the fingers for a reasonable cost intake. That’s the big expense.
                  Cheap Headers, cheap mufflers, 2 straight pipes, clamps, adapters & hangers. End it at the rear axle.
                  Pace Performance ready to run Distributor (inexpensive)
                  Upgrade cam later.
                  • Like Like x 1
                  • 318willrun
                    318willrun Stomper 4x4... we kept energizer in business
                    7,169
                    4973
                    Sep 13, 2013
                    I'm here
                    Local Time:
                    12:03 AM
                    yep, a good 4bbl and intake along with a set of headers, that roller 360 with 308 heads will be around 300 hp.
                    • I had the exact '89 360 TBI in a D150 with single exhaust, 3.21 gears, stock auto and it ran 15.3's in the 1/4.
                    • It will also have a block off plate where the mechanical fuel pump would be, and the fuel pump eccentric will be on the cam already.
                  • SLOPAR72
                    1,291
                    583
                    Jan 5, 2016
                    Richmond, VA.
                    Local Time:
                    1:03 AM
                    I talked to the guy for a few minutes yesterday evening and I told him to KISS on the deal..... RRR you are right about headers and I told him a set of Dougs Headers are exactly what this setup needs.
                    I sold him a Weiand 8007 intake for it. The heads will come off and will likely get a retouched valvejob and fresh springs. The guy has a fast foxbody so if it got near 300hp he will be more than content....
                    JW
