Jonnylightening
Ok guys this past weekend i swapped my eddy perf. Intake for a Weiand Stealth. I did do the gasket match on the stealth as i did also with the eddy. I bought a new QFT Slayer. I took the car around the block and it didnt do bad but had a stumble to it. So i took it back and hooked up my vacuum gauge via manifold port. The gauge didnt budge. Maybe its broke or line has a hole? Nope everything checked out fine i sucked on it and the needle moved no problem. So i hooked it back up....nothing. I bleaped the throttle needle jumped to 20-25 and back to 0. Pulled the pvc plug off the back and almost shut off the car. Any idea why o have no reading at idle but do when i bleap the throttle?
