Lower control arm shaft bushing, 65 Barracuda
Suspension, Steering and Chassis
  1. circlepilot
    circlepilot FABO Gold Member FABO Gold Member
    701
    457
    Nov 15, 2014
    El Dorado, Arkansas
    Local Time:
    2:15 AM
    By now (since these type of control arms have been in use for ages) there must be an easier way to remove the "outer shell" from the lower control arm, shaft bushing. I'm rebuilding my lower control arms and I have pressed out the shafts and the rubber portion of the old bushing. I removed the inner shell from the shaft by splitting the shell with my Dremel. (Not covered in the service manual) The service manual says to remove the outer shell, which is still in control arm (probably for 54 years) "by cutting it with a chisel. Use care not to cut into control arm."
    There must be an easier way?
    Norm
  2. mopowers
    mopowers Well-Known Member
    4,774
    1899
    Feb 15, 2006
    West Sacramento, CA
    Local Time:
    12:15 AM
    Weld a washer to it and press it out. Some folks use a large pipe tap and press that out. Or just go to town with a hammer and chisel. I tend to favor the washer and welder.
    • Like Like x 1
    • Thanks! Thanks! x 1
    • 66fyssh
      66fyssh Don't Stop Believin' FABO Gold Member
      5,362
      4408
      Jun 22, 2013
      Northwest GA
      Local Time:
      3:15 AM
      I couldn't find an "easy" way. I used a sawsall to cut four slots, then went to town with a hammer and chisel. Once I got them beat in towards the center, I was able to knock them out from behind.
      Not my idea of fun...but I got 'um done!!
      • Jim Lusk
        Jim Lusk Well-Known Member
        4,406
        752
        Mar 8, 2006
        Fresno, CA
        Local Time:
        12:15 AM
        While this is covered in a sticky thread at the top of this forum these are the two most common ways to remove the outer shell.
        • Thanks! Thanks! x 2
        • circlepilot
          701
          457
          Nov 15, 2014
          El Dorado, Arkansas
          Local Time:
          2:15 AM
          I knew if I asked, I would get some answers. I've been on this forum five years and have really picked up some great information. I've been a professional mechanic since the age of 16 and I still learn something new everyday. :thumbsup:
          Thanks.
          Norm
          • Agree Agree x 1
          • Craig Burriss
            Craig Burriss Well-Known Member
            302
            197
            Aug 30, 2017
            Statesboro Georgia
            Local Time:
            3:15 AM
            I couldn’t get mine out to save my life. I tried literally everything that everyone recommended but still couldn’t, thought I’d try and beat them out with a BFH but ended up bending the entire LCA. Great excuse to by some QA1s lol
            • Agree Agree x 1
            • circlepilot
              701
              457
              Nov 15, 2014
              El Dorado, Arkansas
              Local Time:
              2:15 AM
              Also, I need to referrer to the "how to " site more often. I will in the future, thank Jim.
              Norm.
            • ClydeT
              ClydeT Member
              22
              25
              Dec 18, 2018
              SW Ohio
              Local Time:
              3:15 AM
              Just did my 69 Dart last week. Bought a press from Harbor freight for $100 and a 1 3/8" tap off Ebay for $12.99. Was a piece of cake.
              • Like Like x 3
              • Craig Burriss
                302
                197
                Aug 30, 2017
                Statesboro Georgia
                Local Time:
                3:15 AM
                The tap is a really good idea. Wish I had tried that
                • Agree Agree x 2
                • Like Like x 1
                • grimreaper
                  grimreaper Cross Member
                  3,540
                  725
                  Jul 8, 2005
                  Gillette, WY
                  Local Time:
                  1:15 AM
                  The tap is my usual method but sometimes they don't press easily and rather than break a tap I cut a groove on those with my sawzall and chisel 'em out.
                • Tims 66 Cuda
                  Tims 66 Cuda Mopar mid life crisis
                  226
                  121
                  May 28, 2018
                  Poquoson, Va
                  Local Time:
                  3:15 AM
                  That press is the chit cause they are a mofo with out it
                  • Agree Agree x 2
                  • circlepilot
                    701
                    457
                    Nov 15, 2014
                    El Dorado, Arkansas
                    Local Time:
                    2:15 AM
                    BTW: I forgot to ask earlier...There is nothing in the manual, that I can see that covers play limitations, or how much is too much play in the torsion arm / adjuster and how play would be removed.
                  • Jim Lusk
                    4,406
                    752
                    Mar 8, 2006
                    Fresno, CA
                    Local Time:
                    12:15 AM
                    My most watched video at 49k.
                    • circlepilot
                      701
                      457
                      Nov 15, 2014
                      El Dorado, Arkansas
                      Local Time:
                      2:15 AM
                      Just ordered some plates. Thanks for the videos Jim.
                      • Like Like x 1
