Lower radiator hose recommendations needed
Heating / Cooling / AC
  1. Chris Luther
    Chris Luther New Member
    4
    0
    Jul 11, 2019
    Stony Point
    Local Time:
    11:32 PM
    I'm working on a 68 Dart with a 70 slant six block and an unknown radiator, definitely not a 68. I ordered a lower hose for a 68 from Rockauto. I had to wrestle it into place but it fouls on the fan belt, no way to adjust it out of the way. It's a non-A/C, auto trans car. I have the old hose that I removed which did fit but it has no markings or numbers. Thought about bringing it to the parts store and trying to match it up to something. I don't want to use a 'universal' hose. Any ideas?
  2. Professor Fate
    Professor Fate Push the button, Max...
    1,277
    1656
    Jan 13, 2020
    Wisconsin
    Local Time:
    10:32 PM
    Welcome!
    Pics of the offending hose and your setup would help, but you're on the right track- take the old hose that fits to the parts store and see if you can match something up. If they won't look, or let you look, change parts stores.
    Good luck!
  3. Chris Luther
    4
    0
    Jul 11, 2019
    Stony Point
    Local Time:
    11:32 PM
    Here are a couple of pix.
  4. Professor Fate
    1,277
    1656
    Jan 13, 2020
    Wisconsin
    Local Time:
    10:32 PM
    Just a thought- did you try flipping the hose around in the other direction?
  5. Chris Luther
    4
    0
    Jul 11, 2019
    Stony Point
    Local Time:
    11:32 PM
    Yeah, the other way around it won't work at all. I cleaned and detailed the engine to look a little more like a 68 without going into a restoration, I think it came out pretty clean. Anxious to fire it up and tune it but this hose has the project on pause.
  6. Professor Fate
    1,277
    1656
    Jan 13, 2020
    Wisconsin
    Local Time:
    10:32 PM
    That looks like it might be a '73 and up radiator, could start your search with that?
  7. Chris Luther
    4
    0
    Jul 11, 2019
    Stony Point
    Local Time:
    11:32 PM
    Yes, the Rockauto photo of a '73 Dart hose looks spot on. For $12 I'm going to just go ahead and order it. Thanks!
  8. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    57,238
    22878
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    10:32 PM
    That same philosophy works with women also... :D
    • Like Like x 2
    • DrCharles
      DrCharles Well-Known Member
      1,125
      908
      Jun 7, 2012
      West Plains, Mo.
      Local Time:
      10:32 PM
      That reminds me, I once saw a patient who had a big tramp stamp with her own name in the center. I told my nurse afterwards that it's probably so the guy behind her knows which name to call her. She about peed herself laughing :D
      • Like Like x 1
      • krazykuda
        57,238
        22878
        Aug 20, 2007
        Orland Park, IL
        Local Time:
        10:32 PM
        That's reminds me of a girl tattooing "Exit Only" just above her ass...
      • Duggie
        Duggie Well-Known Member
        427
        293
        Apr 10, 2020
        Tacoma WA
        Local Time:
        8:32 PM
        The lower hose on my '64 /6 looks just like that. Advance Auto was the only place in town that had one that wasn't universal. I found that if I twisted both ends and clamped very little twist into the curve where the belt was hitting, it would clear by "enough". I have 2K miles since installing the lower hose with no more belt to hose contact issues.
        Good luck!
      • halfafish
        halfafish Damn those rabbits, and their holes! FABO Gold Member
        2,006
        1800
        Aug 14, 2016
        SW Washington
        Local Time:
        8:32 PM
        What is the diameter of your water pump fitting and the radiator fitting?
