16gI have yet to explore the wheel well fully. I know the lip is rusty in a few spots, and I'm willing to bet there are some sections I'll need to patch, at the very least on the bottom front.
Any tips?
I know your not done with your prep so just throwing this out there, You should be using something in between those patches to afford some type of corrosion protection. Whether it be epoxy prime and just clean up enough to weld and some weld-prime etc inside and out of each layer. I like vice grips or sheet metal screws over the spring clamps. Tighter fit up easier to weld and less chance of bumping something out of place when you can't see through a helmet.
Just in general, if your repairing or making patches you want to use the same gauge material as you are replacing. You do not want to use pieces of an 18-20g aftermarket qtr. patch panel to repair a 14-16g. structural inner rocker as was suggested.
Nice progress so far. How's the part of the wheel well that the seat belt stud is attached to?
Thank you both! My initial approach has been to cut out the absolute minimum, as I wasn't sure on next steps all the time, or best approach. Each time I talk about this more, and hear the advice, I lean further and further towards a quarter skin. I believe I read that AMD is no longer producing quarters for dart sports, or even some earlier models such as the 71/72, but I've reached out to double check.
Always get the parts FIRST before you cut anything. Definitely should have done full quarters but I think you know that now.
The areas I cut out needed to be removed regardless. That's why I stuck with only the minimum to start. But yes, a quarter skin is still in my future, just researching to see which manufacturer is "better" based on community feedback since AMD is no longer producing. I won't be removing any more metal until I have the part in hand and can draw out my areas to cut. I don't think I need a full quarter, the skin should be plenty. Worst case scenario, in my head anyway, is getting a salvage piece. Maybe I'm just being optimistic though!
I've made plenty of mistakes, and "wish I woulda done it this way" moments in hindsight. Being a first timer, I've come into it expecting such, and hoping I don't screw up too much.
Hell, sanding the entire car, top to bottom by hand was shitty; took me all of last spring/summer. A time sink that I'll never get back. If I could go back in time I would have just sent it in to get blasted. Perhaps my next car!
I can think of two tools right now that will make your life alot easier, clecko's, and a flange tool.
I would put the whole qtr on since you have it. Less finish work going across the sail panel verse running a seam all the way down the side of the car. I would build a sleeve for the sail panel joint over trying to flange it.
