Confusedcuda
Hello, What's the best way to lubricate a Lokar kickdown cable. I thought I seen on here before there is some fitting you can buy, to help the process. What is the best thing to use? Thanks!
I'm with Trailbeast. Dry graphite. I always lube the cable up real well before I install it.
Spit on your hand and rub the top a little, that usually gets the job done.
My second choice might be a silicone spray.
