71 Duster, manual brakes, disc front and rear, 7/8 bore yes or no ? thanks
what would be best for this application,im leaning toward 7/8 thanks for any input disc front and rear and manual brakeAre you asking what it has? Or what would be best? OEM MC was either 15/16 for power disks, or 1-1/32 for manual disks.
thanks for the reply7/8 should be good. Larger bore would have higher pedal pressure; the 1-1/32, for example, is a brute. The reason the power disks had a smaller bore than the manual was they had different mechanical leverage.
Ok thanks AJ I guess I will go ahead and order it. Going with the dorman m80266.15/16 is just right for factory brakes, is very modulate-able, and has a nice feel to it.I might have a little more travel than you are used to, but that is the trade-off for modulation control.
the feel is a very good match to a diaphragm clutch.
