Machine Work on bellhousing require Clutch Pivot relocation?
Manual Transmission & Clutch Discussions
  1. Bret2094
    Bret2094 Angry wrench enthusiast
    62
    4
    Oct 25, 2013
    College Station , Texas
    Local Time:
    6:01 AM
    I scored a free 4 speed bellhousing, but it has the 4.35 size bearing retainer hole , and I am placing it behind an OD unit with the 5.125 size bearing retainer hole. To make it work, I plan on taking it to a machine shop to have it punched out, but I noticed that the holes that the fork pivot screws to will get wiped out in the process. Do people usually get the holes retapped and drilled in the same degree and orientation as before, or does the new diameter of the hole screw the geometry up?
    Bret
  2. hemi446
    hemi446 Well-Known Member
    678
    208
    Aug 3, 2013
    Ellicott City MD
    Local Time:
    7:01 AM
    I will let you know I'm doing one for a friend because he had a 10" 1/2 bell housing and wants to go to a Hemi box in his 68 DART GTS and it has the bigger bearing retainer and that is going to wipe out the pivot bolt holes. I'm thinking just drill and tap new holes by bolting up the transmission with a release bearing on it and clutch fork see were the bracket is going to line up. It my require some welding to build up the area and machining it down so there is a nice flat surface to mount the bracket to and enough meat for the bolts to be tighten down good and tight. Good luck I'll post pictures as I good if that will help
  3. Coronet 500
    Coronet 500 Well-Known Member
    434
    90
    Dec 24, 2011
    Ontario Canada
    Local Time:
    7:01 AM
    Search bellhousing alignment and if it is out of tolerance you could get it machined offset to eliminate the need for offset bushings.
  4. Daves69
    Daves69 FABO Gold Member FABO Gold Member
    4,865
    2966
    Feb 20, 2011
    WestOfChi
    Local Time:
    6:01 AM
    If you haven't yet, you might try to find out if someone would like to do a swap before you rip and tear.
  5. fklskv
    fklskv Well-Known Member
    1,105
    578
    Aug 14, 2011
    Lackawanna, NY
    Local Time:
    7:01 AM
    Passon should have what you need. I just made the same swap but into a scattershield. I had to use a different ball stud mount and different fork pivot mount.
    http://www.passonperformance.com
