Magnum 360 water pump shaft seal replacement
altraditional
Member
Tallinn
Case is, I have the water pump modified (rad. hose tube in different location, some other grindings) and it started leaking from the hole. So it is "one of a kind" and I want to repair the pump, not to replace it.
Is it possible to replace the seal, or all of the moving parts, shaft, bearings, etc? Where can I get the seal and parts?
There are several places on the web that will rebuild yor existing pump. I do not have first hand experience with any of them. One of the places is located here in Az is called Kellogs. Some places sell rebuild kits, not sure if they have your application. Google "car water pump rebuilding".
