kb67mopar
I've got some 360 magnum parts (same parts will fit a 318) that I have no use for. I have a set of heads, valve covers, timing cover, and intake manifold. The engine was run low on oil and threw a rod, so the block, crank and rotating assembly got scrapped.
All parts are located in Luxemburg Wisconsin. I'll ship things if you really want, but doubt they are worth the cost. $100 for everything to get it off my shelf.
