Magnum Heads/ LA Block Head Bolts
Baxter61
Oregon City, OR
Is the only reason you need different head bolts is because the magnum uses different bolts? Basically can you use stock Magnum bolts? Or is there actually a special bolt set?
Are they a 1 time use bolt? And aren't some a different length than for an LA motor/
