Anyone using the magnum serpentine belt setup with just the water pump, alternator and a/c compressor? Pics would be awesome along with any other info. Thanks.
Do you know the belt length or part number you used for this? I am doing the same setup.Hope this helps.... This is the belt diagram. The Tensioner is mounted to the right head. It is a factory mounting with pully.
If you are using the factory set up, and should, be sure to go with the Magnum ALT and A/C compressor with a low profile outlet on the A/C compressor.View attachment 1715516573
Magnum tensioners have an indicator to show when it is centered properly with the correct length belt. I cut a full length belt and clamped it to length with vise grips until the indicator was centered. This way you can check for proper length, mark it, remove it, and measure it. Works perfectly on all setups that are not stock. The length is part of the of the belt part number.Do you know the belt length or part number you used for this? I am doing the same setup.
