Making progress on my 71 440 Demon
Big Block A body Tech
  1. SuperStock426
    SuperStock426 FABO Gold Member FABO Gold Member
    269
    159
    May 20, 2020
    Fort Oglethorpe Georgia
    Local Time:
    8:09 AM
    Engine and transmission installed.
    • Like Like x 9
    • Thanks! Thanks! x 1
    • SuperStock426
      269
      159
      May 20, 2020
      Local Time:
      8:09 AM
      Ladder bar setup..
      • Like Like x 7
      • SuperStock426
        269
        159
        May 20, 2020
        Local Time:
        8:09 AM
        • Like Like x 4
        • SuperStock426
          269
          159
          May 20, 2020
          Local Time:
          8:09 AM
          QA1 shocks installed on the front..Sport mirrors installed too.
          • Like Like x 2
          • Riff Raff
            Riff Raff Well-Known Member
            250
            170
            Dec 31, 2015
            Central Ny
            Local Time:
            8:09 AM
            Looking real sharp! Congrats!
            • Like Like x 1
            • MOPARMAGA
              MOPARMAGA Well-Known Member
              358
              137
              Aug 20, 2019
              Seattle Wa
              Local Time:
              5:09 AM
            • SuperStock426
              269
              159
              May 20, 2020
              Local Time:
              8:09 AM
              Thanks..I toned her down a bit to drive on the street..11:1 compression..Ohio Crankshaft 4340 crank 3.75 stroke..Eagle rods..Ross pistons..Comp Cams 600 solid with Harland Sharp 1.6 rockers taking it to 640 lift..EDM Comp lifters..Indy heads.. Smith Brothers pushrods..ATI dampener..Victor 440 intake MSD distributor and 6AL digital box..825 race demon carb..Transmission is a 727 torqueflite..Steel planeteries from a diesel transmission..roller rear support..ultimate sprag from A&A..5 clutch drum..4.2 shift lever..Turbo Action Cheetah manual valve body..PTC converter and a Cheetah shifter..Rear gears are 4.56...Oh..and it has TTI 2 inch headers..Been meaning to post what all is in the engine and transmission..
              • Like Like x 1
              • MOPARMAGA
                358
                137
                Aug 20, 2019
                Seattle Wa
                Local Time:
                5:09 AM
                Cool, you answered a question of mine in your reply, my 471 build is going to end up around 11.3:1 I've got all the aluminum possible besides the block. And also the plum crazy on her looks amazing, my 70 dart is f4 green kind like a babies runs.
              • MOPARMAGA
                358
                137
                Aug 20, 2019
                Seattle Wa
                Local Time:
                5:09 AM
                Looks like a 9.90et car
                • Like Like x 1
                • SuperStock426
                  269
                  159
                  May 20, 2020
                  Local Time:
                  8:09 AM
                  What type of cylinder heads are you running?..The one thing I'd have done different is use a low deck block..Clearance in some places are a bitch..I'm having trouble getting the steering coupler to clear the header tube..If I'd have known just how tight it was going to be I'd of went with a QA1 k member with coil overs on the front along with rack and pinion steering..If I have to pull her out on down the road that's what I'll do..
                  • Agree Agree x 3
                  • MOPARMAGA
                    358
                    137
                    Aug 20, 2019
                    Seattle Wa
                    Local Time:
                    5:09 AM
                    Trick flow 240s on a 400 block & coated fenderwell headers, I'll most likely modify them slightly so I can fit a decent height tire up front
                    • Like Like x 1
                    • SuperStock426
                      269
                      159
                      May 20, 2020
                      Local Time:
                      8:09 AM
                      Definitely the way to go with that low deck..A friend of mine bought a set of those 240s..I believe those come CNC ported?
                    • SuperStock426
                      269
                      159
                      May 20, 2020
                      Local Time:
                      8:09 AM
                      Mine had fenderwell headers too when it was drag raced only..Id of stayed with them but couldn't run a taller tire so I cut panels out of an old Valiant and patched up the holes cut for fenderwell headers and bought under chassis TTIs..I wanted 1 7/8 headers but TTI didn't make those only 2 inch and 1 3/4..I was afraid the 1 3/4 would have choked the engine down so I went with 2 inch..Id give a hundred bucks just to have a quarter of an inch clearance in some places..Looks like I will be dinging a header tube..
                    • famous bob
                      famous bob mopar misfit
                      17,575
                      7049
                      Aug 14, 2011
                      okla
                      Local Time:
                      7:09 AM
                      I `ve got 2'' tti`s on my 440/505 in a 68 fastback, everything clears , but is tite as h--- , no bent tubes , aftermarket k-frame w/ rack n pinion , 1/4'' IS ABOUT THE MOST i HAVE SOME PLACES 1/8'' .
                      You can elongate the holes in the floor plate of ur steering column to get a hair more room on the shaft -------------I`ve read a borgeson steering box is smaller than the mopar box too .
                    • Sublime one
                      Sublime one 72 Demon FABO Gold Member
                      3,910
                      7785
                      Mar 17, 2018
                      Fargo
                      Local Time:
                      7:09 AM
                      Here is a pix of my Demon badge, the bright red and yellow just didn’t look good on mine so I took the badge decal to a local graphics guy and he customized to a different color for me. I love your build it is gorgeous. I am stuffing a 6.1 in mine so I totally understand the no room thing!
                      • Like Like x 1
                      • SuperStock426
                        269
                        159
                        May 20, 2020
                        Local Time:
                        8:09 AM
                        You have a aftermarket K frame?..Does Borgeson make a manual steering box?
                      • SuperStock426
                        269
                        159
                        May 20, 2020
                        Local Time:
                        8:09 AM
                        Looks good.
                      • famous bob
                        17,575
                        7049
                        Aug 14, 2011
                        okla
                        Local Time:
                        7:09 AM
                        Yes aftermarket k frame , not the best driving car I`ve ever had tho.
                        I think they do make a manual box , at least thats the way I took it .
                        • Like Like x 1
                        • SuperStock426
                          269
                          159
                          May 20, 2020
                          Local Time:
                          8:09 AM
                          • Like Like x 4
                          • Joeycurl
                            Joeycurl Well-Known Member
                            74
                            40
                            Oct 28, 2019
                            Bay Area,CA
                            Local Time:
                            5:09 AM
                            nice build!
                            • fishmens67
                              fishmens67 Well-Known Member
                              8,417
                              6091
                              Nov 10, 2012
                              idaho
                              Local Time:
                              7:09 AM
                              Pure Badass car. 451 ?
                            • SuperStock426
                              269
                              159
                              May 20, 2020
                              Local Time:
                              8:09 AM
                              30 over 440...446
                              • Like Like x 1
                              • SuperStock426
                                269
                                159
                                May 20, 2020
                                Local Time:
                                8:09 AM
                                Finally got the header off and dinged..Got it put back together and the steering coupler doesn't hit the header tube now..Got the steering column in finally.
                                • Like Like x 2
                                • SuperStock426
                                  269
                                  159
                                  May 20, 2020
                                  Local Time:
                                  8:09 AM
                                  Steering column in and new steering wheel installed.
