Making progress on my 71 440 Demon
Big Block A body Tech
  1. SuperStock426
    SuperStock426 FABO Gold Member FABO Gold Member
    262
    157
    May 20, 2020
    Fort Oglethorpe Georgia
    Local Time:
    11:46 AM
    Well fellers..It looks like I'm going to have to get a shorter air filter element..Don't think it's going to fit under the 5.5 inch cowl scoop on my hood.
    • Like Like x 2
    • Agree Agree x 1
    • MOPARMAGA
      MOPARMAGA Well-Known Member
      354
      137
      Aug 20, 2019
      Seattle Wa
      Local Time:
      8:46 AM
      • Thanks! Thanks! x 1
      • mygasser
        mygasser FABO Gold Member FABO Gold Member
        665
        363
        Aug 17, 2010
        faversham, kent. united kingdom
        Local Time:
        10:46 AM
        could you use a deep/deeper drop base for the filter?
        neil.
      • SuperStock426
        262
        157
        May 20, 2020
        Local Time:
        11:46 AM
        I have a drop base on it now..I'll probably just drop down to a 4 inch filter...If I drop it down anymore it'll interfere with the throttle setup I have on it..
      • mygasser
        665
        363
        Aug 17, 2010
        Local Time:
        10:46 AM
        yeah it looked like you had a drop base, i just wondered if you could go deeper but no is the answer to that.
        neil.
        • Like Like x 1
        • 71Demon440
          71Demon440 Active Member
          39
          41
          Nov 9, 2011
          Stow, Ohio
          Local Time:
          10:46 AM
          Where did you get the valve covers from ?
        • RustyRatRod
          RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
          64,478
          37442
          Jun 7, 2010
          Georgia
          Local Time:
          11:46 AM
          Put a taller scoop on it. A real scoop. A HEMI scoop. lol
        • SuperStock426
          262
          157
          May 20, 2020
          Local Time:
          11:46 AM
          Screenshot_20200912-165346.png They're identical to Indy valve covers without the logo.
        • SuperStock426
          262
          157
          May 20, 2020
          Local Time:
          11:46 AM
          The scoop on it now is 5 1/2 inches tall.
        • SuperStock426
          262
          157
          May 20, 2020
          Local Time:
          11:46 AM
          Wiring up my MSD 6AL box and installed my new Auto Meter Sport Comp 2 gauges.
        • famous bob
          famous bob mopar misfit
          17,532
          7016
          Aug 14, 2011
          okla
          Local Time:
          10:46 AM
          covers are kick A$$ , been watching those sinse they`ve been out .
          • SuperStock426
            262
            157
            May 20, 2020
            Local Time:
            11:46 AM
            Not bad for a little over one hundred bucks.
          • famous bob
            17,532
            7016
            Aug 14, 2011
            okla
            Local Time:
            10:46 AM
            They wre $99 when summit first started carrying them , and I didnt pull the trigger .
          • DrCharles
            DrCharles Well-Known Member
            939
            685
            Jun 7, 2012
            West Plains, Mo.
            Local Time:
            10:46 AM
            I have the MP cast covers (currently on iron heads) and I'm constantly fighting leaks at the rear of the heads. Thinking of switching...
            How do these Summit covers compare in height? I had to put in a shorter blower motor just to barely clear the right-side cover.
          • famous bob
            17,532
            7016
            Aug 14, 2011
            okla
            Local Time:
            10:46 AM
            I dont have them , but I think they were 3.25 or 3.5 tall.
            Ur lucky , I had to go to a hotrod heater under the dash , my raised port heads are about 3/4'' off the firewall on the pass side .
          • SuperStock426
            262
            157
            May 20, 2020
            Local Time:
            11:46 AM
            I believe I paid 106.00 for mine.
          • SuperStock426
            262
            157
            May 20, 2020
            Local Time:
            11:46 AM
            The valve covers I have work pretty good on my Indy Heads because the valve cover rail on my heads are wide..l used the blue Moroso rubber style valve cover gaskets.
          • SuperStock426
            262
            157
            May 20, 2020
            Local Time:
            11:46 AM
            I also removed my heater and blocked the hole off with a block off plate.
          • SuperStock426
            262
            157
            May 20, 2020
            Local Time:
            11:46 AM
            These work pretty good
          • SuperStock426
            262
            157
            May 20, 2020
            Local Time:
            11:46 AM
          • DrCharles
            939
            685
            Jun 7, 2012
            West Plains, Mo.
            Local Time:
            10:46 AM
            I have one of those... but it's very "springy" with the weight of a 5" tach on it. I think it will be more usable with a strip of dense foam rubber wedged inside the elbow.
          • SuperStock426
            262
            157
            May 20, 2020
            Local Time:
            11:46 AM
            Want to sell it?. I'll pay TOP DOLLAR for it.
          • DrCharles
            939
            685
            Jun 7, 2012
            West Plains, Mo.
            Local Time:
            10:46 AM
          • SuperStock426
            262
            157
            May 20, 2020
            Local Time:
            11:46 AM
          • DrCharles
            939
            685
            Jun 7, 2012
            West Plains, Mo.
            Local Time:
            10:46 AM
            No, sorry... even though it bounces a bit, something has to support my tach. And I can't hold it in my right hand because I have a 4-speed, even if I'm not petting the dog Dart 12-11-19 (2).jpg :)
