Mattax
Just the facts, ma'am
Yes. He can either rig something or contact Parmount (sp?) if its Sun. Hoppy might be able to help him too, but in either case its going to cross the border.There is an older mechanic here in my town with a Distributor machine, but he told me by phone that he can only spin point type distributors, he thinks, has never spun an electronic distributor
If its a Chrysler built distributor:
Some examples of guys adjusting the curve on Chrysler built distributors.
Here Rick works through and posts the effects of his changes
And an example of how that changes a bit with different combustion characteristics for later engine
I spill the beans on shaping the curve here
If its got Mallory advance, they're easier and harder:
Here's a thread with a link to another thread explaining the adjustments on them.
There's only so much that can be done with them due to the geometry.
Is this normal?
Hi, posted some picks of my dizzy,if you can zoom in there is white plastic shavings in the center where the spring clip is.I and getting ready to pull it out to add fbo plate. How would shavings get in there with the rotor on,and the rotor is white?
www.forabodiesonly.com
And long thread about slew rate but quickly in the beginining demonstrates why one does not want to stop the advance at 2500 or 3000 rpm.
Testing the HiRev 7500
Are these ignition systems as junk as many claim, or is the real issue in the misunderstanding of how the electronics work? You be the judge.
