master cycler resteration 67 barracuda
273 ball
hemet
Hi I have a master cycler that needs to be restored , , any good places that you can
think of . ?
For many years White Post Restoration was a well known name from its advertising Hemmings yellow 'book'.
Depending on what is needed for the restoration, see what you can find locally.
How bad is the bore scratch or pitted? If its not too bad, a honing and a kit with new seals will put it in working order. Might also need new residual valves in the outlets (drum brakes).
Original drum brake master cylinder will have a bolt down top.
Correct disk/drum master cylinder will have a bail hold down and larger resevoir.
