master cyclinder can it be moved
Big Block A body Tech
  1. moparraceman
    moparraceman Well-Known Member
    1,268
    98
    Aug 1, 2010
    mansfield ohio
    Local Time:
    12:24 AM
    have a 72 duster with a 440 motor stock master cyclinder cant get the valve cover off on drivers side sugesstion thanks
  2. 2BAD4U812
    2BAD4U812 Well-Known Member
    102
    28
    Apr 21, 2019
    ill60041
    Local Time:
    12:24 AM
    Mopar relocation bracket Summit
    • Agree Agree x 2
    • Alaskan_TA
      Alaskan_TA Well-Known Member
      4,698
      2612
      Nov 12, 2004
      PA
      Local Time:
      1:24 AM
      I had a '70 with a 440.
      Part of the trick was to leave the top side low to its mounting surface & rotate the bottom edge up.
      There was some wiggling involved & it took a while.
      That was also over 30 years ago & I promised myself to never add another 440 to another A-body.
      Just too much of a PITA for street driving & the related maintenance.
      • Agree Agree x 1
      • kursplat
        kursplat FABO Gold Member FABO Gold Member
        1,601
        717
        Aug 24, 2010
        so cal
        Local Time:
        10:24 PM
      • moparraceman
        1,268
        98
        Aug 1, 2010
        mansfield ohio
        Local Time:
        12:24 AM
        thanks
      • DartOS
        DartOS Well-Known Member
        514
        105
        Mar 24, 2010
        Texas
        Local Time:
        12:24 AM
        You can buy a relocation plate.
      • moparraceman
        1,268
        98
        Aug 1, 2010
        mansfield ohio
        Local Time:
        12:24 AM
        ok thanks
      • AndyF
        AndyF Well-Known Member
        1,315
        1013
        Feb 23, 2009
        Oregon
        Local Time:
        10:24 PM
        The crude Mopar one for a lot of money or the nicer one from Mancini for less money. Choice is yours. Offset Master Cylinder Adapter
      • RustyRatRod
        RustyRatRod 30 Degrees Outta Whack FABO Gold Member
        52,930
        20743
        Jun 7, 2010
        Georgia
        Local Time:
        1:24 AM
        Sure. You can put it anywhere, really. The Aussies put um on the passenger's side. Some postal vehicles have them moved over there too, but have a long bar that rotates and pushes the rod in. But if you don't need to move slap to the other side, the MP kit or similar will work.
      • mopower440
        mopower440 Well-Known Member
        531
        64
        Oct 12, 2014
        TN.
        Local Time:
        12:24 AM
        Im not sure i understand how the pushrod is attached to the brake pedal when using the offset adapter..How do you move the pushrod over to match the new offset hole?
      • moparraceman
        1,268
        98
        Aug 1, 2010
        mansfield ohio
        Local Time:
        12:24 AM
        dont know need more research
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        11,415
        1828
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        12:24 AM
        I have an offset bracket for that. I may be not be using. It’s not much of an angle really. Kim
      • RustyRatRod
        52,930
        20743
        Jun 7, 2010
        Georgia
        Local Time:
        1:24 AM
        Most I have seen people simply use a longer pin/bolt to connect to the brake pedal.
      • oldkimmer
        11,415
        1828
        Nov 11, 2006
        Local Time:
        12:24 AM
        U can make the push rod 1 inch longer, or buy a adjustable p/r from Doctor Diff. Kim
        • Like Like x 1
        • mopower440
          531
          64
          Oct 12, 2014
          TN.
          Local Time:
          12:24 AM
          yes but as far as moving the push rod over to match the offset adapter, how do you do that because the pushrod is already bolted to the side of the brake pedal..?
        • famous bob
          famous bob mopar misfit FABO Gold Member
          13,099
          3784
          Aug 14, 2011
          okla
          Local Time:
          12:24 AM
          I bought a 1/2" thick offset adapter on ebay , way cheaper than either one listed above. Was black anodized, fit perfect, but I forgot how far over it moved the cyl. tho.
          You can cut and thread ur existing rod, and thread both ends , then use a 1/2'' threaded rod coupling to put it back together, adjust it to the same thickness of the adapter , to keep the stock pedal height , weld it when u have it the way u want it , and grind off (I turned mine down in a lathe), to get a bunch of the bulk off to make it look like something that belongs on a car. You will have to grind the original rod size a little to get it round enough to thread , no biggee -------
          Not really enough of an angle change to worry about , mine has been on the car for a few yrs. , no problems. With raised port heads, I still had to mill the lower fin off my mopar perf. valve cover tho , to get it off.
          I even had s/steel flex lines built , so I could loosen the bolts and swing the master cyl over a little if needed , but don't have to do that .
