Like the title says one of the caps on the master cylinder is seeping.
I wrapped a little paper towel around the lid and looking at the pictures you can see it’s soaking up brake fluid.
I’ve tried ever so slightly shimming the rubber gasket in the lid and have tried a little less brake fluid. Always the same result.
Has any one ran across or have any ideas for a solution, Or know were to get replacement caps. I’ve had it for several years and I don’t have paperwork with part numbers.
Thanks
Thanks
