FlDart360
Question about brake master cylinders. The previous owner swapped out the drum brakes on the front only of my 71 Dart Swinger to disks from some other A body. He never changed the master cylinder from when the car was running all drum manual brakes. The car stops fine, but I noticed they make a master cylinder for a 73 and up A body for manual disk drum combination which is now what I have. If I should need to replace the master cylinder should I consider a different model and would any other modifications be needed? Would I notice anything different?
Thanks.
Thanks.
