I just purchased a 1974 Plymouth Duster with a 360 HP Magnum Block. It has Wilwood 10 inch discs on the front, manual brakes. The master is leaking from the lid, time for an upgrade. I read some people using the late model truck master cylinders with the dr diff adapter. Some are saying bigger bore is the way to go and some are saying smaller bore. I want to be able to stop better, I never had a car with manual brakes so I am new to all of this. This is the master with the 1 1/8" bore I was looking at with the adapter plate. Any help is appreciated thanks
