[SOLD] Megasquirt MS2 and wiring harness
amcervantes
Portsmouth, VA
Selling my Megasquirt MS2 setup. I had it in a 72 dart with a 5.2 magnum engine. Never had a problem. Selling everything to plug and play. Megasquirt, engine wiring harness,dash harness. Engine harness is still on car but will be removed this weekend. Ill even through in the mini HP laptop I have that I used for it with the meqasquirt program on it. Battery is crapped out and its a little slow but works good for running megasquirt. Asking $300
What would I need to still get if I buy this kit if I switch from full mechanical/carb ser up? Also how many injectors does this snd your harness support?
Can I ask what you are changing to?
What year is the 318 magnum? Will the stock sensors on the magnum motor I have interface with the megasquirt? Or does the megasquirt need GM sensors?
Thanks,
J J
