Mexican Mopar 360: i need to know how to have more horsepowers
Mopar Performance Issues
  1. ez_equiel
    ez_equiel Active Member
    27
    1
    Sep 13, 2013
    Argentina, Buenos Aires
    Local Time:
    1:26 PM
    Hi my friends, sorry for my bad english. The last month, i buy a mexican valiant super bee with 300 hp. In mexico city, we are to 2400 meters above sea level, and the car does not reach more than 180 km per hour. I'm interested that changes you may make to the car to exceed 200 km per hour, about the height takes away power. If you can help me, i can appreciate that.
    Regards
  2. harrisonm
    harrisonm Well-Known Member
    3,823
    4284
    Jan 16, 2005
    Topeka, KS
    Local Time:
    4:26 PM
    Hola. Before we try to help you, we need some information. Tell us more about the engine if you can (camshaft, intake manifold, exhaust manifold or headers, what kind and size of carburetor, transmission and rear end gears. it is hard to make recommendations without any information.
  3. ez_equiel
    27
    1
    Sep 13, 2013
    Local Time:
    1:26 PM
    360 V8 engine and 300 hp, the three-speed Torque Flite 727 automatic
    carter thermoquad 800 cfm
    dana 44 3.54:1
    stock intake manifold
    stock exhaust manifold
    [​IMG]
  4. Lustle
    Lustle Well-Known Member
    1,391
    558
    Jul 26, 2015
    Lethbridge
    Local Time:
    9:26 AM
    I'm curious why the intent on higher KMH? With your setup you'll never get that in the 1/4 anyways. A car like that would need in the area of 700 horse to hit 200 KMH in a 1/4 mile, as a guess. How soon/short do you wanna hit 200 KMH? What kind of budget do you have? How much of the car are you willing to change? I mean you could put in a higher rear gear and probably go over 200 KMH, but it would take you forever to get there.
    Just as a guess, I'm assuming 26/27 inch tires. With that 3.54, and 5000 RPM, you'd top out at around 180 KMH. Swap the gears out to 3.07s and you'll hit barely 200 KMH. It'll take a while to get there. It won't go as quick off the line. But you'll hit your goal of over 200 KMH, that's the cheapest way of doing it. Or swap the rear end out for a 8-1/4 and then you can put gears in the 2.71 or 2.94 range. Both of which you'll hit over 200 KMH. But then you'll have a weaker rear end unless you spend the money building it.
    In the end, the power of the engine has a limited effect on high speed in your case. The altitude isn't affecting your top speed. Just how soon you hit it. It really doesn't take much power to move a vehicle at high speed. Which is why a VW bug can cruise down the highway with a whopping 50 HP. The power determines how quickly you get there. If your goal is top speed. Forget about power. Gear it for top speed. If your goal is how quick you can get to 200 KMH, well then you need to worry about power. And budget.
  5. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
    22,043
    9219
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    10:26 AM
    Judging by the rust in the cowl/firewall, it's probably a good thing it can't go more than 180. Ima thinking you need to prove the integrity of the chassis first. If that visible rust-out is any indication, theres gonna be other serious problems, Say the frame rails and the inner apron to firewall, and apron to frame, areas. And the T-bar anchors.
  6. doug 371
    doug 371 Well-Known Member
    2,262
    526
    May 29, 2004
    Regina, SK CANADA
    Local Time:
    4:26 PM
    rear gear swap for sure will help...
  7. 69_340_GTS
    69_340_GTS Well-Known Member
    4,635
    3159
    Jul 11, 2014
    Torrington, CT
    Local Time:
    11:26 AM
    200 kmh = 124 mph, in case anyone is confused.
    (180 kmh = 111 mph)
  8. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    60,835
    27087
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    10:26 AM
    Has dual exhaust been added. 2 1/4' - 2 1/2" with an H-pope or x-pipe will help it greatly.
  9. moper
    moper Well-Known Member
    15,853
    2071
    Dec 27, 2004
    eastern CT
    Local Time:
    4:26 PM
    It should be capable of that now. It jsut might take some time to get there. How well is it tuned? Does it pull cleanly to 4500-5000 rpm?
  10. - Marvin -
    - Marvin - Well-Known Member
    581
    729
    Mar 9, 2015
    Vienna, Austria
    Local Time:
    5:26 PM
    I think ez iquiel does not intend, to reach 200 Kmh on the quarter, but on the highway...
    These speeds were reached by the super bees of the Mexican police.
    They were famous for their high-speed-pursuit capability:
  11. 69_340_GTS
    4,635
    3159
    Jul 11, 2014
    Torrington, CT
    Local Time:
    11:26 AM
    Right, '75-'76 Mexican "Valiant Super Bees" were actually the front 1/2 of a Dodge Aspen with the back 1/2 of a Plymouth Volare. And under Mexican mostly non-existent pollution laws the 360s in these were rated at 300 hp.
  12. Dartnut
    Dartnut Don't hate me because i'm beautiful
    11,875
    5012
    Apr 19, 2007
    Southern Alberta
    Local Time:
    9:26 AM
    Where do you drive that you need to go that fast anyway?
    The first thing i would do is to make sure the car is safe enough to go that speed.
    This means tires, brakes, suspension, steering, and most importantly, body structure.
    It looks to me as that the car is rusty, therefore weak, and therefore unsafe at any speed over 20 km/h..........
    Let's see some more pictures of the car from all angles and the frames, torsion bar crossmember, etc.
  13. Woods74
    Woods74 Broke Senior
    6,001
    243
    Aug 21, 2010
    Seattle, WA
    Local Time:
    8:26 AM
    It's not about horsepowers. It's about torques.
  14. krazykuda
    60,835
    27087
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    10:26 AM
    Au contrare...
  15. tarvin890
    tarvin890 tarvin890
    1,096
    344
    Jul 7, 2014
    Mopar Land
    Local Time:
    11:26 AM
    GEEZ are you guys kidding me.... he is in Argentina for gods sake.... lol thats probably as good as it gets down there for this guy...have a little compassion for his situation. We dont all have lotsa $$$$ and he probably has even less and loves the hobby and is just trying to have fun...
  16. tarvin890
    tarvin890 tarvin890
    1,096
    344
    Jul 7, 2014
    Mopar Land
    Local Time:
    11:26 AM
    Id drop that gear to 273 or 323
  17. rumblefish360
    rumblefish360 I have escaped the evil Empire State! FABO Gold Member
    42,215
    14388
    Jun 21, 2005
    Florida
    Local Time:
    11:26 AM
    Why question is want/need for high speed?
    I can not even believe I'm reading that!
    Insane!
  18. rumblefish360
    42,215
    14388
    Jun 21, 2005
    Florida
    Local Time:
    11:26 AM
    The first rule of HP is breath! Breath deep and effectively!
    Upgrade its breathing ability with;
    A Weiand Action Plus for the stock TQ
    A RPM for a squarebore carb like a Holley or Edelbrock.
    Add headers and a 2-1/2 exhaust with free flowing mufflers. Join the exhaust pipes with an "X" pipe.
    Use an upgraded ignition, a multi spark helps.
    Let us know how that works for you before we suggest a high rpm cam and spring set up for more power and rpm.
  19. tarvin890
    tarvin890 tarvin890
    1,096
    344
    Jul 7, 2014
    Mopar Land
    Local Time:
    11:26 AM
    have you ever been to argentina? he may need to run from gangs....and fast.... not a fun place....maybe this is his escape from the dooodooo down there...... going fast is the least of those people problems....
  20. baracus
    baracus Well-Known Member
    508
    127
    Jul 19, 2010
    ga
    Local Time:
    11:26 AM
    Show us some pictures of the entire car, I'd like to see what these look like.
  21. diymirage
    diymirage HP@idle > hondaHP@redline
    26,828
    25378
    Oct 12, 2012
    michigan
    Local Time:
    11:26 AM
    you didn't notice the angle iron subframe welded into that engine bay?
    have another look at the power steering pump, you'll see it
    as for the HP/torque debate, I was always told that HP determines the speed with which you hit a brick wall, but torque determines how far the wall moves after you hit it
    as for the OP, consider the engine as a huge pump, the more efficiently you can get air/fuel in and exhaust out, the more (and quicker) power it will make
    so as mentioned, address the intake and exhaust
  22. Bulldozer
    Bulldozer free ice cream sandwiches
    14,986
    2332
    Oct 16, 2011
    behind the wheel
    Local Time:
    10:26 AM
    lol I think that's the battery tray...
    a turbo and a set of 245 gears should get you to somewhere around 180 MPH...
  23. harrisonm
    3,823
    4284
    Jan 16, 2005
    Topeka, KS
    Local Time:
    4:26 PM
    Ez Equiel,
    From what I can see, you will need to do 4 things to get to 200kph (about 120mph):
    1. First (and muy imortante) make sure your car is safe to go that fast. Check the tires, check the suspension and check the brakes carefully. I would not want to be going 120mph with bad ball joints and or bad brakes.
    2. Headers will help your engine breath and give you more power.
    3. A high performance intake manifold will also help with power. And make sure the carburetor is working properly.
    4. I would think that 3.23 (or something close to that) would be a good gear set for you.
  24. Mopar Tim
    Mopar Tim FABO Gold Member FABO Gold Member
    25,664
    21428
    Nov 29, 2014
    vista CA.
    Local Time:
    8:26 AM
    Torque gets a load moving
    HP keeps it going.
    :burnout:MT
  25. AJ/FormS
    22,043
    9219
    Jan 19, 2014
    Local Time:
    10:26 AM
    Just put some decent valve springs on it, and let her rev. Well that works here at 900ft(277 meters). At nearly 10,000 ft IDK.
    • Like Like x 1
