[SOLD] Miller Bearing Remover Set
hunt2elk
WI
Miller C-4335, SP-111, and rod sets. Pinion and main shaft rear bearing remover set. $25 plus shipping.
Miller C-4335 is the drive pinion and main shaft rear bearing remover for the A-390 three speed manual transmission.
C-4335-1 is the bearing part, SP-111 is the puller part, and the threaded rods are used between the two, with different lengths for different depths.
I'm not certain if this tool has other uses or not.
