[FOR SALE] milodon 8 quart oil pan, 360 LA
diymirage
HP@idle > hondaHP@redline
michigan
hey guys
when I installed the 360 LA into my duster I did not clearance the K member until it was too late
the oil pan rubbed up against it and actually created a leak
I took the pan back off, sandblasted it and had one of my coworkers TIG weld it
i then repainted it a gold color, close to the stock finish
i guess i was not able to get the gasket lined up properly and it leaked under load (not from the weld, but from the rear, making it look like a bad rear main seal)
so, long story short, im having the oil pan replaced with a stock unit and the milodon will be up for sale
included in this sale is the 8 quart milodon oil pan
the pick up
and the milodon reusable gasket
PICTURE IS OF THE OIL PAN BEFORE I SCRAPED, WELDED AND REPAINTED IT
im expecting to get the car and parts back this Wednesday at which point i will post better pictures of the pan as it is now
it is located in Holland MI 49424
and i am asking $200.00 plus shipping
long story short, I still have this pan and it is still for sale BUT the engine it was under shredded a connecting rod bearing
I cleaned it as good as I could but when I dropped the whole deal of at MRL for a rebuild Mike was against using the pan because there were still little bit of metal in there
considering the time it would take him to clean it (at shop rate) we decided to use a new stock style pan
so, this one is back up for sale, 150 plus shipping
just be sure to clean it when you get it
(pickup still included)
