Milodon oil pans
New Hemi Engine Swaps
  1. Buford19
    Buford19 Well-Known Member
    295
    166
    May 22, 2014
    Kitimat b.c.
    Local Time:
    9:31 PM
    When changing over from a stock gen 3 front sump oil pan, too a Milodon mid sump pan. Can you used the factory oil dip stick?
  2. 1973Barracuda
    1973Barracuda Well-Known Member
    1,569
    1590
    Dec 11, 2009
    Local Time:
    12:31 AM
    I have a 6.1, I have a new dip stick. I also had to knock out a plug in the block.
  3. Buford19
    295
    166
    May 22, 2014
    Kitimat b.c.
    Local Time:
    9:31 PM
    Oh, I was hoping I could use the existing one. What company made the new dip stick( milodon)?
  4. Buford19
    295
    166
    May 22, 2014
    Kitimat b.c.
    Local Time:
    9:31 PM
    Do have any pictures of the location where plug was removed?
  5. 69FBCuda
    69FBCuda Life in the Fast Lane
    1,051
    363
    Aug 28, 2014
    Florida
    Local Time:
    12:31 AM
    Add your "X" amount of quarts, run it to get the filter full, let it set then check the stick. This would be the correct amount. Now make a permanent mark on the dipstick>
  6. rustycowll69
    rustycowll69 Well-Known Member
    1,692
    648
    Feb 19, 2016
    Pacific northwest
    Local Time:
    9:31 PM
    ok, but how do you know how many is "X" quarts?
    Could you figure how far below the pan rail the crank hangs down, then mark the pan accordingly, fill the pan(off the engine) with water or what have you, to the mark then measure how many "X" quarts that takes?
    OR, maybe you could insert the dipstick and mark it directly where it is just below the crank throws. Just throwing these ideas out there, anybody have better ideas?
  7. Buford19
    295
    166
    May 22, 2014
    Kitimat b.c.
    Local Time:
    9:31 PM
    So you are saying I could use the stock dip stick as long as I mark the oil location line?
  8. 1973Barracuda
    1,569
    1590
    Dec 11, 2009
    Local Time:
    12:31 AM
    I do not. With the pan off it is hard to miss. Just look for a round outline. When I bought my pan, the shop informed me I needed a dip stick, now, to be honest, I went ahead and bought it. That is one part I actually didn’t research prior to purchasing.
  9. RealWing
    RealWing FABO Gold Member FABO Gold Member
    718
    170
    Jun 14, 2010
    Ontario
    Local Time:
    12:31 AM
    27FF57FC-5588-40FB-8F3A-8437A48B5DC0.jpeg Photo
    • Like Like x 1
    • Thanks! Thanks! x 1
    • 69FBCuda
      1,051
      363
      Aug 28, 2014
      Florida
      Local Time:
      12:31 AM
      How many quart oil pan is it? Stock is 4+ quart is the Mildon 7 quart? Typically it would be the width or length of the pan that increases the volume and depending on the model, the depth. Under filling could be dire whereas over filling could be damaging also. I would think that if this is a 7 quart pan than you would want to see 7 quarts on the stick
    • RealWing
      718
      170
      Jun 14, 2010
      Ontario
      Local Time:
      12:31 AM
      Simply go to Milodon’s web site Milodon Chrysler Oil Pans
      The capacity for each pan is listed. Filter is in addition to that
      • Like Like x 1
      • rustycowll69
        1,692
        648
        Feb 19, 2016
        Pacific northwest
        Local Time:
        9:31 PM
        oh, sure, you could take the easy way out and read the instructions, but it's not the manly way, hahaha.
      • RealWing
        718
        170
        Jun 14, 2010
        Ontario
        Local Time:
        12:31 AM
        True - only as a last resort!!!!!
      • Buford19
        295
        166
        May 22, 2014
        Kitimat b.c.
        Local Time:
        9:31 PM
        So this dip stick in the picture has been relocated? Just realized the factory dip stick is on the oil pan on my 6.4. Thought I read in your thread that the dip stick you used didn’t fit properly. Guess I will be order another dip stick.
      • RealWing
        718
        170
        Jun 14, 2010
        Ontario
        Local Time:
        12:31 AM
        The Milodon dipstick was too long. I had to disassemble it and shorten it. Are you using the factory or Milodon windage tray? I had many fitment problems with the Milodon tray.
      • loganscuda
        loganscuda DON’T reMember
        1,531
        1169
        Jul 15, 2010
        san antonio
        Local Time:
        11:31 PM
        I used the factory dipstick 05 truck.
      • Buford19
        295
        166
        May 22, 2014
        Kitimat b.c.
        Local Time:
        9:31 PM
        Was hoping to use the factory if it is possible.
      • ace26
        ace26 Well-Known Member
        134
        8
        Apr 22, 2006
        Memphis
        Local Time:
        11:31 PM
        The one I used with my Milodon pan, I got from bouchillon performance, small amount of tweeking to go around the tti's, works great, looks like a factory stick that has been modified for the correct length. Just had to knock out the block plug on driver side. Not great pic but you get the idea.
        • Like Like x 1
        • Map63Vette
          Map63Vette Well-Known Member
          1,519
          25
          Apr 19, 2010
          Lawrence, KS
          Local Time:
          11:31 PM
          I have a 5.7 that came from a car, 2006 i believe. I used a factory dipstick for my Milodon pan, though I think it was the truck dipstick. It's kind out there in a weird place, but it works fine for me.
        • rjsam
          rjsam Active Member
          44
          0
          Mar 20, 2009
          Local Time:
          11:31 PM
          What's the best way to remove plug in block thanks
        • Map63Vette
          1,519
          25
          Apr 19, 2010
          Lawrence, KS
          Local Time:
          11:31 PM
          I don't think I had a plug in mine, but if I did I think it was just a matter of taking the oil pan off and hitting the dipstick hole with a punch. I think it's just like a typical freeze plug in that it's just a little cup. You can see the bottom side of the hole with the pan off so you can just knock it out with a long enough punch.
        • RealWing
          718
          170
          Jun 14, 2010
          Ontario
          Local Time:
          12:31 AM
          Correct. Use a punch
