[SOLD] Misc. garage clean out linkages parts pieces rods antenna bezel wire loom
bbrroowwnn
never re member
Drums, PA
cleaned out the garage....misc. items....linkages and rods are from mopars but I don't know what....there is an A-body antenna bezel....wire looms.....new battery terminal covers....maybe shifter or pedal mounts...there is a speedometer cable stabilizer that goes on your cable after it comes out of the trans to keep it from kinking where the hard bend is....look at pictures and see if anything interests you....the blue rod may be the center section for kickdown linkage on a 4 barrel setup....not sure.....if you need any measurements or more pictures just ask....lets say nothing over 10.00 each + shipping.....some as low as 3.00 + shipping....just let me know what you are interested in and I will give you a price.....or take the whole lot for 40.00 + shipping.....located in Drums PA.....postal M.O. works for me...
there is an entire 64/65/66 kickdown in there....its the big triangle bolt on bracket, stud bellcrank and 3 rods.
