Misc under hood brackets & linkages
petty437
Kent, Ohio
I have some misc parts & pieces that I have no idea what they are from. Any help is appreciated. Thanks.
1 throttle return spring brkt (front of manifold)
2 throttle cable holder ?
3 kick down linkage upper pivot, missing brkt it goes on.
4 rear mount kick down upper pivot / throttle cable holder ( might be mount for #3)
5 choke thermal pull down (slant 6???)
6 another throttle return spring forward mount
7 kick down lever attaches to transmission
8 kick down rod upper ( carb to upper pivot #3)
9 throttle or kick down return spring. (
10 kick down rod upper pivot to lower pivot ( with lower pivot attached)
11 kick down rod, lower pivot #10 to transmission #7
Please if I missed the mark on any of these correct me.
Some of the parts look V8 some look Slant 6.
@Oldmanmopar can you shed some application and years knowledge
#8 is a 4bbl piece very similar to what a 340 or 360 would use.
