MJ's 71 Beaver (Dart)
Members Restorations
  1. mj's friend
    mj's friend Member
    11
    16
    Apr 7, 2022
    gilbert az
    Local Time:
    5:23 AM
    This will be the official build thread for MJ’s 1971 beaver (supposedly demon dart). Long story short, mj is my work buddy. We work at a turbine engine overhaul shop in az. I’m a mechanic and he was one of my inspectors. He just took a job in management so he has less time than ever to make a build thread. I told him I’d make the build thread and he will chime in when he’s not looking down the barrel of a shotgun contemplating his recent career move. We’ll probably pester you guys with stupid questions within this thread. Feel free to pound the keyboard in anger with caps lock on, we won’t be offended.
    The car had a slant 6 and auto that we just pulled out. The car is in decent shape. We’re just working on getting the mechanicals in order. No cares for body work at the moment and the interior is just fine for now.
    The donor engine/trans combo going in is a 383 and going with a 440 source stroker kit/stealth heads and a 727 trans that’s gonna be gone thru. The motor seems to be a 1969 with 906 heads. It was said to have had a spun rod bearing. It did indeed. The Shumacher slant 6 to BBM mounts recently arrived. We'll probably dump the bare block in to test fit and notch the k member.
    The rear was a 7.25” or whatever tf, no one cares. Mj picked up a fully built 8.75”, 3.23 ratio with new suregrip and 5x4.5” axles and a 7290 yoke . Don’t ask how much it was but it’s beautiful and it’s A body dimensions. Driveshaft will be measured once the motor and trans are in the car. Rear suspension will likely be caltracs and split mono leaf springs from calvert as well. Wouldn't mind sticking with rear drums but we have nothing to start with as of now so suggestions are welcome.
    Here's the aluminum radiator that was in it with the slant 6. The question is will it be big enough for the big block?
    That's it for now, I just wanted to get this thread going. We'll have questions and want opinions on front suspension, disk brake conversion, subframe connectors, engine/trans stuff... Just pretty much everything. So far 440 source seems like a good vendor for engine components. P-S-T for suspension rebuild and Brakes. Shumacher for the mounts.
    Any and all advice is welcome, even if its "sell it all to save your marriage, buy a street bike instead!"
    • Like Like x 4
    • Stranglehold
      Stranglehold Well-Known Member
      76
      77
      May 28, 2020
      Vancouver,WA
      Local Time:
      5:23 AM
      Nice! I just received Schumacher mounts about a month ago for my 340, they were scarce. Haven't fitted them yet. Cool build!
      • Agree Agree x 1
      • Garrett Ellison
        Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
        4,523
        3740
        Jan 1, 2018
        Southwest VA
        Local Time:
        8:23 AM
        How much crank you putting into the 383? The radiator may be okay if it's got the 1 inch (or are they 1 and fractional, I forgot?) pass tubes in it. But in Arizona, it may take a 3 row radiator with large pass tubes, and a high flow water pump such as a FlowKooler or PRH.
        • Like Like x 1
        • Murray
          Murray FABO Gold Member FABO Gold Member
          2,862
          2114
          Apr 19, 2010
          San Jose, California
          Local Time:
          5:23 AM
          We specialize in stupid questions.
          • Agree Agree x 2
          • CFD244
            CFD244 These pretzels are making me thirsty. FABO Gold Member
            1,924
            2170
            Sep 7, 2017
            Northern Ontario, Canada
            Local Time:
            8:23 AM
            Can't wait to see the progress. Good luck.:popcorn:
            • Agree Agree x 1
            • Darter6
              Darter6 Well-Known Member
              5,058
              2509
              Jan 16, 2008
              Nevada
              Local Time:
              5:23 AM
              Looks like a great starting point. Not too many unmolested 71/72 Demons around anymore.
              For those that don't know the BEAVER was the other name that Dodge was thinking about using.
              Glad the Demon name won .
              As far as cooling the 383 you might get by with the radiator you have, but may find the lower hose is on the wrong side.
            • barbee6043
              barbee6043 barbee 6043 FABO Gold Member
              16,453
              9874
              Jul 20, 2008
              Shepherd, Texas ( SE Tx)
              Local Time:
              7:23 AM
              Good luck! Any AC in that garage????
            • Plymouth 65
              Plymouth 65 Floorable Deplorable
              1,859
              1847
              Jun 27, 2016
              Mich
              Local Time:
              8:23 AM
              Love Demons, looks to be a solid foundation for a great sounding build. 65'
              • Like Like x 1
              • ACME SS
                ACME SS Well-Known Member
                84
                123
                Apr 13, 2022
                Emmett, Idaho
                Local Time:
                6:23 AM
                It looks like a great project and in the right hands. My 71 demon was also born a 6 cylinder but now has a 318 and I have been unhappy with the feel of it at highway speeds. I had a 6 cylinder Demon in high school and I don't remember it being scary to drive. I got a lot of good suggestions when I posted a question but one in particular got my attention. Apparently these cars came with a front sway bar when equipped with a V-8 (someone may correct me but that was my take on it). I just received a Hellwig sway bar and plan to install it this week in hopes it will tighten up the front. It may be something to consider with that monster you are installing.
              • mj's friend
                mj's friend Member
                11
                16
                Apr 7, 2022
                gilbert az
                Local Time:
                5:23 AM
                Yeah I saw they had a lot that were out of stock. We were lucky the slant 6 to bbm a-body motor mounts were one of the few in stock
              • mj's friend
                mj's friend Member
                11
                16
                Apr 7, 2022
                gilbert az
                Local Time:
                5:23 AM
                I’m thinking I have mj talked into the 3.75” stroke (434” iirc). I like a good rod angle. And not clearancing the block. Keeping 255 drag radials somewhat planted to the ground will be difficult no matter what with a warmed over big block, the 496” rotating assembly seems excessive.
                as for the radiator I’m not sure about the internals, I didn’t look at it too hard. I think we’ll give it a try and just keep a close eye on the temp gauge.
                • Like Like x 1
                • mj's friend
                  mj's friend Member
                  11
                  16
                  Apr 7, 2022
                  gilbert az
                  Local Time:
                  5:23 AM
                  Interesting. We’ll be going in with the bigger torsion bars but a swaybar is not out of the question. Luckily the heads will be lighter and I think the rotating assemblies from 440 source claim to be lighter than factory components as well but it’s still gonna be a pig with the big block in the front.
                • mj's friend
                  mj's friend Member
                  11
                  16
                  Apr 7, 2022
                  gilbert az
                  Local Time:
                  5:23 AM
                  It’s not bad yet. I’ve lived here my whole life and done motor swaps on 117* days with no ac and it sucks. But it’s doable (iTs a dRy hEaT). I’m hoping this motor isn’t ready until September or later. We still need to get rear suspension and brakes under it and rebuild the front susp and convert to disk before we get to excited about engine work.
                  • Like Like x 1
                  • mj's friend
                    mj's friend Member
                    11
                    16
                    Apr 7, 2022
                    gilbert az
                    Local Time:
                    5:23 AM
                    God dammit . I need to look at more pics of bb swaps. Thanks
                    • Like Like x 1
                    • barbee6043
                      16,453
                      9874
                      Jul 20, 2008
                      Local Time:
                      7:23 AM
                      S E TEXAS! It ain't the heat that kills ya, its the humidity (and lack of wind!).
                      Yea dry heat as in a friggin OVEN!!!!!!
                      You know the humidity might be just a little high, when the sweat has run off ya balls and your boots are soaking WET!!!!:poke:
                      • Like Like x 1
                      • Agree Agree x 1
                      • French demon
                        French demon Well-Known Member
                        256
                        253
                        Jul 12, 2020
                        South of France
                        Local Time:
                        2:23 PM
                        Correct me if I'm wrong, but my '71 slant-six Demon has a front sway bar. Was it an option? Maybe standard with front disc brakes?
                        (sorry, no better pic)
                      • A56
                        A56 MoPar Affliction FABO Gold Member
                        7,298
                        21913
                        Jun 24, 2014
                        White Oak, N.C.
                        Local Time:
                        6:23 AM
                        Fender Tag Option Code S31 is 70-71 only for front sway bar. I would think maybe it's part of a towing package, or suspension upgrade. or someone added it later on. I see you have power disk brakes which may have been part of this upgrade. Check your fender tag and or build sheet if available.
                      • A56
                        7,298
                        21913
                        Jun 24, 2014
                        White Oak, N.C.
                        Local Time:
                        6:23 AM
                        ...and contribute them
                        • Like Like x 1
                        • French demon
                          256
                          253
                          Jul 12, 2020
                          South of France
                          Local Time:
                          2:23 PM
                          :thankyou:
                          No S31 code on the fender tag, nor on the build sheet.
                          But the number 39 in the "FT S/BAR" build sheet box (fourth line)
                          • Like Like x 2
                          • mygasser
                            mygasser FABO Gold Member FABO Gold Member
                            1,465
                            1108
                            Aug 17, 2010
                            faversham, kent. united kingdom
                            Local Time:
                            7:23 AM
                            it's easy enough to move the hose fitting on ally rad's if you want to go ahead with what you have.
                            • Agree Agree x 2
                            • Darter6
                              5,058
                              2509
                              Jan 16, 2008
                              Nevada
                              Local Time:
                              5:23 AM
                              Not sure of the year but around 1975 on the big block Cordoba/Charger the lower hose is on the passenger side. You may try from 75-(78 the last year) for a big block water pump housing . Don't quote me on this but maybe.
                            • mj's friend
                              mj's friend Member
                              11
                              16
                              Apr 7, 2022
                              gilbert az
                              Local Time:
                              5:23 AM
                              This is why we’re here
                            • TheGrateRonzini
                              TheGrateRonzini Well-Known Member
                              1,022
                              879
                              Oct 25, 2017
                              Western New York
                              Local Time:
                              8:23 AM
                              440 source offers a pass side inlet water pump housing
                              • Like Like x 1
                              • Agree Agree x 1
                              • ACME SS
                                84
                                123
                                Apr 13, 2022
                                Emmett, Idaho
                                Local Time:
                                6:23 AM
                                Hmmm. bigger torsion bars... not a bad idea
                              • rumblefish360
                                rumblefish360 I have escaped the evil Empire State! FABO Gold Member
                                43,373
                                15488
                                Jun 21, 2005
                                Grant Valkaria, Florida
                                Local Time:
                                8:23 AM
                                Your correct, I did the below.
                                They sure do and I did it myself. The housing and pump made of aluminum saves a lot of weight.
                                I ran my 400/727 w/ the /6 bars. It’s not what I’d recommend but it was something I got used to quickly.
                                @mj’ s friend
                                @mj’s friend
                                @mj’sfriend
                                @mj's friend
                                (WTF is going on here?)
                                both if need be here… LOL!
                                I also used a Summit racing aluminum radiator. It made the stock fan a no go. Watch your thickness on the radiator.
                                • Like Like x 1
